Question about Schlage B362 716 DBL CYL DEADBOLT EA 20538435
How to reinstall a Schlage deadbolt - Schlage B362 716 DBL CYL DEADBOLT EA 20538435
Deadbolt wont lock on inside of door only on the outside
Posted on Mar 10, 2013
  • 3 Answers
SOURCE: how do you remove knob on schlage deadbolt so that
turn knob as usual, there should be a hole in the bottom after you turn it. push a small screwdriver and it will pop right off.
Posted on May 14, 2009
  • 4 Answers
SOURCE: remove schlage deadbolt
there should be a small spot in the brass usualy on the bottom to pry the faceplate off. or the face plate may twist off try both under there you will find the skrews
Posted on Feb 08, 2009
tbirdfan1
  • 3051 Answers
SOURCE: deadbolt stuck on lock position
hello there:
you will need to dissasemble the deadbolt there is a plastic piece that wears out over time and once this wears out it wont work right probably best just to replace the deadbolt (sorry)
Posted on Jul 22, 2009
  • 670 Answers
SOURCE: How do I unmount a schlage keyed deadbolt?
There should be two hole plugs on the face of the interior deadbolt housing, above the key slot. They must be pryed out to access the screws. Unless it is installed inside out, then the the plugs will be outside. Yes I have seen this before or I wouldn't have mentioned it.
Posted on Sep 27, 2009
  • 16 Answers
SOURCE: Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Posted on Jun 21, 2010
Testimonial: "I will try your suggetion. Thank you."
My schlage keypad will not do anything anymore i even tried new batteries has happened on all three of my locks
Probably need to be reset to factory default. Since it is all your locks you probably change all the batteries same time.
provided link to Schlage
http://www.schlage.com/en/home/contact-us.html
Oct 01, 2016 | Schlage Deadbolt. Century Satin Nickel...
How do i remove the plugs covering the screws on the schlage deadbolt?
Schlage FAQs Schlage
The double cylinder deadbolts are keyed on both sides. On the interior side of the home there are drive pins (sometimes called screw covers) covering up the screws. Recommended method: Indent the center of each drive pin with a nail punch. Then use a carbon tip drill bit (about the size of a pencil lead) and ONLY go down 1/8". The drive pin will disintegrate. The drive pins will need to be replaced as they are no longer usable.
Sep 16, 2014 | Schlage Deadbolt. Double Cylinder Deadbolt...
How to remove plugs from schlage deadbolt?
Thank you for your inquiry. These are small plastic plugs on your double cylinder deadbolt. These are just held in through friction. Just take a small screwdriver and pop them out. Factorylocks.com can help you with your Schlage hardware needs.
Mar 29, 2013 | Schlage BE365-PLY BE365PLY626 Satin...
Will a schlage b60 fit in the same holes as a schlage regent deadbolt
I'm not sure what the regent deadbolt is, but if you look at the attached Factorylocks.com youtube video it will show you how to resize a Schalge B60 deadbolt.
Dec 18, 2012 | Locks & Locksmithing
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Need to reinstall Schlage deadbolt and knob after painting
Ok. So what is the problem? The reinstall should be straight forward.
I'm Mike BTW
Sep 07, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Deadbolt stuck on lock position
hello there:
Jul 22, 2009 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
How to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Sep 21, 2008 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Schlage B362 716 DBL CYL DEADBOLT EA 20538435 Logo
201 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
