Question about Casio CTK810 61 Key Keyboard
I dont know what the midi is on my keyboard when its connected to the computer. What do you have to do?
    President:
  • 1,138 Answers
Your manual should give you the info you need. Here is a link:http://www.casio-intl.com/emi/standard/ctk810.html Go to the bottom for info on Vista drivers. The other systems drivers are on the bundeled CDRom that came with your purchase. If you don't have it ,try here:http://support.casio.com/download.php?cid=008&pid=340&rgn=5 Hope this helps.
Posted on Oct 13, 2010
Keyboard conection
Most are a 3 - 5 pin midi, you need midi cables and a midi interface, they do make a
midi - usb cable for connecting keyboard to a computer,
hope this helps?
Mar 04, 2015 | Music
I cant connect my yamaha ypt 320 to my pc using the midi
Assuming you have a MIDI interface on your computer, you need to connect the MIDI cables between the keyboard and the PC. You cross connect, that is, in to out and vice versa. You will ALSO need the driver software for the interface in the PC AND most importantly, some software in the PC to handle the MIDI for instance to record.
Mar 27, 2011 | Yamaha YPT320 61 Key Personal Keyboard
How to connect psr-3000 to computer
You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface: - you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
Mar 07, 2011 | Yamaha Full-Size Keyboard
Fruity loops old version with casio keyboard
You haven't said whether or not you are using a demo ,version of FL. If you purchased they have Lifetime Free Updates here:http://flstudio.image-line.com/documents/lifetimefreeupdates.html If you didn't purchase, try downloading the newest demo version here:http://flstudio.image-line.com/documents/download.html Some features of demo programs become disabled after a certain time period. I don't know if midi device recognition is one of them for this program. Try hooking your keyboard up first, making sure that you have the correct drivers for the keyboard, your USB adapter etc. Then start FL and see if the program lists your keyboard in the midi device list.
Mar 03, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Jan 21, 2010 | Casio Privia Keyboard Case
Cant hook up my casio 2000ctk 2 computer
if its a midi keyboard, it should be in your audio settings in control panel under the midi device, ive used fl studio with these before, or reason. hope this helps in some way.
Nov 30, 2009 | Casio CTK810 61 Key Keyboard
Connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
Aug 17, 2009 | Casio 76 Key Smartmedia Keyboard
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Apr 04, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Casio CTK810 61 Key Keyboard Logo
77 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
