Question about Sony XM-2100GTX Car Audio Amplifier
Amp and LED turn on for a split sec but the dies
My stuff was working fine for about 8 mo. Then I accidentaly broke the remote terminal off of the amp. So for a while i just had the remote wire TAPED to the gold that was still left. It worked like this for another 3-4 mo. then sometimes i would hit a bump and it would knock loose. I kept re-taping it for a while and it was still working like i had just gotten it. One day, after it falling off, i tried to hook it back up and now it just does the same thing. When i first touch the remote wire to the remote terminal, the LED turns green for a split second before dimming very low or going out completely. If i quickly remove it and put it back, it doesnt turn on again, but if i wait 2-3 seconds, it does the same thing. The first time this started happening the subs kicked on for a few seconds and then died. Ever since then it's been the same deal. The amp doesnt smell fried all the fuses(including the power fuse) are good.???????????
  • 109 Answers
Well you obviously aren't getting a signal to the amp telling to turn on. You need to take the amp to an audio shop who has a test bench and ask them to determine what other problems you might have. Quite honestly though there are better amps out there maybe you should just upgrade.
Posted on Jun 19, 2008
Sharp LC-70LE733U won't turn on, remote or the power button? I was able to enter service mode and then test the TV it works fine.
After enter in Service mode press Ch down & Vol Down from LED back panel.
Select 8/10 page by pressing up & down button from remote
Select EEP , Press Ok button from remote
EEP - will show running
Switch off LED from main's and restart your LED will work properly.
Jun 08, 2017 | Sharp Televison & Video
Remote starter comes only briefly and shuts off
Factory Remote Starter Quits After 5 Seconds - Diesel Place ...
www.dieselplace.com/.../340832-factory-remote-starter-quits-after-5-sec...
Nov 23, 2009 - 11 posts - ‎8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ... check engine light on wont shift
Oct 28, 2011
remote start
Oct 14, 2008
More results from www.dieselplace.com
Factory Remote Start Problem - 1999-2006 & 2007-2013 Chevrolet ...
www.gm-trucks.com/forums/topic/114985-factory-remote-start-problem/
Jun 12, 2010 - 10 posts - ‎8 authors
Factory Remote Start Problem - posted in 1999-2006 & 2007-2013 ... Sounds like you may have an intermittant code coming in and the dealer should be able to pull it out.2008 Sierra SLT ECSB Z71, Corsa Touring, and GMPP CAI .... the remote start button again the truck WILL shut off and the only way to ... Burning smell, white smoke - 2014 / 2015 / 2016 ...
Jan 11, 2014
2008 Silverado Electrical Issue
Aug 19, 2012
Making Factory Remote Start Run Longer
Dec 21, 2010
2000 Sierra, Starts Then Dies - Code 1631
Dec 4, 2008
More results from www.gm-trucks.com
Jan 05, 2016 | 2008 Chevrolet Silverado 2500HD
Reprogram astrostart j5f tx2000
Get under the dash or where the unit is located.
You will see 8 or 9 dip switches on the unit with an LED beside them.
Turn switch 1 and 8 on.
Press and release the brake. (LED will flash)
Press and hold start button on remote. (LED will flash and parklights will flash once.
Turn switch 1 and 8 to off.
Press and release the brake (LED will flash once)
In future would be a good idea to supply vehicle details etc as can sometimes be a known condition , that saves time looking it up , good luck
Nov 18, 2014 | Cars & Trucks
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
I just brought universal remote control it an 8 way diital slx rc050 i can get it to pair with my accousic solutions sp 101 amp have you got any codes that would work for this please
try this if you need the manual let me know. (PLEASE rate if it was helpful)
If you are programming the remote for a brand/model that is
not listed in the Popular Brand List or the Direct Code Entry
(e.g. Wharfedale, Acoustic Solutions etc), it is recommended
that you use the Learning Mode (go to section 4).
Follow the steps below to program your remote using the
learning function.
1. Press and hold the device key you wish to learn for 3 secs.
The LED turns ON when the key is pressed but turns OFF
after 3 secs indicating that the key can be released.
2. Release the Device key, LED turns back ON.
3. Press and release the RECORD key, the LED turns off
when the key is pressed and turns on after release, the
remote is now in the learning mode.
4. Press and release the key on the RC050 that you want to
learn to, the LED will blink once and then remain ON with a
lower brightness to indicate it is ready to learn.
5. Face the head of RC050 to the head of your original
remote control, leaving a gap of 5cm (2”).
6. Now press and hold the original remote key (the teaching
key), do not release this key until the LED on the RC050
this indicates an error. Repeat steps 4-6 to correct the
error.
7. LED remains on, repeat steps 4-6 for other key functions to
be learned.
8. Press and release EXIT key to exit learning mode at any
time, the LED turns off.
9. If no keys are pressed for more than 15 secs while in
this mode, the remote exits the mode and the LED turns
OFF
good luck
4. Learning Mode
Dec 18, 2009 | Televison & Video
Reprogram remote
xl-7 programming instructions first you need to stuff your head up under the dash and locate your module drivers side upper corner under dash does it say programmable transmitter (the first models had no programable modules) if it says that then......
1 confirm all doors are shut and key is out of ignition
2 open drivers door insert key and turn to on within 10 sec
3 turn ignition switch to off in 10 sec
4 push and release drivers door switch 3 times in 20 sec
5 turn ign. switch to on in 10 sec
6 turn ign. switch to off in 10 sec
7 press and hold lock and unlock button on transmitter for 5 sec within 20 sec of step 6 alldoors will lock/unlockto confirm correct process
8 press lock unlock buttons on second remote within 5 sec after step 7 once again all doors will lock/unlock to confirm
9 to add another remote up to a max of four repeat steps 1 through 8 this was taken directly out of an owners manual supplement that comes with a new keyless entry kit (part number for a xl-7 or grand vitara can't remember which one it goes to but it works on either one is 84900-67810) which you would have to purchase if yours is not programable these instructions are the same for vitara, grand vitara, xl-7 and the esteem hope this helps
Jul 05, 2008 | 2002 Suzuki Grand Vitara
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
Jan 26, 2008 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Amplifier Not powering on.
Amplifier power problems are generally pretty easy to troubleshoot as long as you have access to a digital multimeter. You need to check the DC volts on the power terminal and on the remote terminal. For the amplifier to turn on, each terminal needs to show around 12 volts. From the sound of it, I suspect a problem with your main power wire, but the multimeter will make certain. If you show voltage on both terminals (with the black probe on the ground terminal) and the amp still doesn't turn on, then there's a defect in the amplifier.
Jun 25, 2007 | Alpine PDX-4.100 Car Audio Amplifier
LED power protection light not turning on
Check the fuse on the amplifier; if it's good, then you need a multimeter or voltmeter for further testing. With the meter's black probe on your amp's ground terminal and the radio turned on, both the power and the remote terminals should test at about 12 volts. If neither terminal shows voltage, you may have a problem with your ground connection; if both do, there's a problem with the amp.
Feb 20, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Kenwood KAC-9152D Car Amp
use a multimeter to check for power on the +ve wire, could be your fuse, it only rus a sec when you jumper the remote to +ve because the remote cannot give out the nessary current to run the amp.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Sony XM-2100GTX Car Audio Amplifier Logo
96 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
