Question about Kenmore Dehumidifiers
I have two Sears 50 pint dehumidifiers. I have not had any problems with them until now. Both of them have filled up with water but inside the machine and not inside the bucket. Can I fix the problem myselt. Thanks.
  • aidensgrandp Oct 11, 2010
    The first answer I got is nonsensical. Any one could have figured that out. The dehumidifier I have is a kenmore 50 pint model. The water is collecting in the body of the dehumidifier behind the bucket. Once enough water has filled up the unit it begins to leak out on the floor. I have tried to drain the water out of the unit once it has filled it up but to no avail. The water remains in the unit. I hope one of your experts can solve my problem. Thanks
  • aidensgrandp Oct 14, 2010
    I did as you said, but I was unable to get the filter out to clean it. I took all of the screws out of the back to get to the coils and the unit itself. After taking the screws I was unable to pull the back off and I was afraid that I would break somthing. Is there a secret to open the back cover that you know of? I cleaned the bucket and I think that that helped as it is holding water now. How long it is going to last is anybody's guess. Thanks for your help.
    Genius:
  • 1,456 Answers
Hello
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself.
Check the drain tray for debris or mold You may need to pull the filter and clean it. Also try wiping off the unit itself.
Connect your vacuum's brush attachment to the hose, and use it to clean off the evaporator coils inside the dehumidifier unit. Use a stiff brush to scrub off any dirt or debris. Be careful when scrubbing the coils so you do not bend the fins covering them.
If all these do not solve the problem then the drain tray has developed a leak and it should be replaced.
Posted on Oct 11, 2010
  • 10,865 Answers
Hello. It sounds like you have not slid the bucket in as far as it needs to go. Remove the buckets, check the area where the bucket will go and remove any obstacle that may be in the way. Then slide the bucket back in being sure you have placed the right bucket in each dehumidifier. Joe
Posted on Oct 10, 2010
Fan running but no water and hot on inside. 50 pint danby premiere dehumidifier
Compressor not running, possibly because refrigerant is low
Jul 30, 2016 | Danby Dehumidifiers
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
BUCKET DOES NOT FILL WITH WATER
It could be the coil & condensor are dirty.
Or it could be that the humidity level is below what the unit will work at. Below 50% humidity and or 70 degrees Fahrenheit, it generally will not do much.
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. If it actually still runs, I would suggest you take off covers and give the coils a good thorough cleaning. Otherwise the units are not designed to be serviceable aka - "disposable small appliance". if you do dispose of it take it to a qualified recycle organization for Freon products. WHIRLPOOL DEHUMIDIFIER Parts Model ad75ust0 Sears PartsDirect
Aug 08, 2013 | Whirlpool 75-Pint Dehumidifier
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
Jul 09, 2009 | Kenmore Dehumidifiers
Sunbeam 50-pint dehumidifier
That's pretty normal. Most of these portable units blow quite a bit of heat.
May 26, 2008 | Maytag M3DH30B2A Dehumidifier
No water filling in tank (whirlpool Gold AD70USS 70 Pint Per Day)
the unit has a sealed system leak that need to be repaired by sears 1-800-905-9505 for service
Apr 13, 2008 | Whirlpool Gold AD70USS 70 Pint Per Day...
Power lose
I have a 45 pint. I have to slide the bucket in and out of the unit multiple times. Make sure to wait a few seconds after each time to see if it will recognize no water (sometimes the red light comes on, but then changes it mind). Also, I've found that leaving the bucket a little crooked will make it respond. It sucks, I know. Mine is only a year old too. Should not be a problem like this!
Sep 14, 2007 | Frigidaire FDL45P1 Dehumidifier
Dehumidifiers Logo
52 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
