Question about GE WBSE3120B Top Load Washer
Washer leaking I purchased my washer awhile ago and now it occasionally leaks water from under the bottom after I wash about 2 loads of clothes. The hoses are on tightly and there is no water dripping from them. The water seems to drain to onw side. Our dryer is next to it so the water drains under the dryer as well. Is it something loose or time to upgrade?
  • 833 Answers
This is hard to trace but is often tracked to a loose hose connection or less often, a defective seal or gasket. Disconnect utilities to the machine. Carefully tip the machine over from the back to that the front is at a 45 degree angle or so from vertical and brace it. Use a strong light to look for a water stain. Determine what to do from there.
Posted on May 30, 2008
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Sometimes there will be grease streaks on the clothes after wash.
the main bearing and seals on the drum side are faulty. this should be under warrenty
Dec 29, 2009 | LG WM-2077C Front Load Washer
There is water leaking out of the bottom of the washing machine
I would check to see if the pump is leaking. Tilt the washer up and put on two peices of 2x4. Shine a trouble lite under washer and take a mirror to look under the washer. Fill 1/2 full of water and advance timer to the spin cycle. Observe to see where the water is comming from. The pump is located at the front of the washer.
If water is leaking from the pump. Replace pump.
Dec 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Intermittent water observed under machine
Difficult if not seen. Most common water on the floor senario is a drain pump leaking:or a perrished pipe from friction.or sometimes, water backs up from the house drainage system due to a restriction.
Heavy water leak during when washing clothes
disconnect the hose on the bottom and see if the seal is good.If it is good, then remove the back panel, start the washer and watch and see what seal is broke and you can visually see the exact spot the water is leaking from.
Feb 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer wabbles and leaks
Tilt the machine forward so the rear feet come off the ground, then set it down, this will reset your feet to level. if problem persists, you can lean the washer on its back and inspect the suspension with a light.
Dec 31, 2008 | Kenmore 23822 Top Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
GE WBSE3120B Top Load Washer Logo
79 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
