Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Ice maker is makeing bad tasting ice water supply is good no bad taste in water , can it be cleaned
    President:
  • 3,113 Answers
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Posted on Oct 30, 2010
It has almost been a month and I would like to enjoy ice that doesn't taste like plastic/plants. What can I do?
you may have algae growing in the ice maker that is producing that taste
remove the ice maker and clean properly including all water lines to the maker
May 26, 2016 | Refrigerators
How do I clean my ice maker?
Curious, does your refrigerator have a water dispenser? How does water taste from it? Your ref. has one water supply for both ice and water. Changing filter was a good start but if it's been over a month, there's something else going on. I would look and see behind your ref. and look at the water line. I've run across a bad plastic tube that causes a bad taste. If you have a plastic one, change it out with a new one. Also, ice absorbs food odors from both the freezer section and refrigerator sections, so check your fridge for bad food. Bell green peppers are the worst, they'll leave a metallic taste. Good luck!
Sep 18, 2015 | Refrigerators
Why does the ice in my freezer taste and smell bad even though I changed the filter?
OLD PIPES NEED REPLACING,OR DID HOUSE WATER LINES SET A WHILE ,HOW LONG DID ICE MAKER NOT BE USED .CAN YOU REMOVE ICE MAKER AND CLEAN?. MOLD MAY OF ESTABLISHED OR RUST.TAKE WATER LINE OFF BACK THIS IS EASIEST. AND RUN 5 GALLONS OF WATER IN A BUCKET.TEST WITH A CLEAR GLASS WITH SOME FROM THE FLUSHING OUT WATER.IF IT DOES NOT CLEAR UP,HAS THE WATER COMPANY RAN TEST ON THEIR PRODUCT.THEIR MIXTURE OF FLUORIDE AND SUCH MAYBE FUNKY.DOES WATER LOOK CLEAN.GET CLEAR GLASS,FILL WITH ICE AFTER IT MELTS SEE IF THINGS AT ALL ARE FLOATING.DO SAME TEST AFTER YOU RUN 5 GALLONS OF WATER OUT OF THE LINE.ICE,MELT LOOK.HOW DOES WATER TASTE OUT OF DOOR IF THAT TYPE.IT CONFIRMS WATER LINE OR OUT OF FLUSHING WATER.IF IT TASTE OK FROM FLUSHING WATER THE SOURCE IS AS DESCRIBED IN THE FIX...
Jul 25, 2014 | Whirlpool Refrigerators
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Bad tasting water
Do not use a steel or plastic braided supply line. They make the ice taste bad.
Dec 29, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad tasting water and ice from fridge and kitchen tap...
Hi!! change your copper line going to the icemaker and also install a water line filter you can buy one at homedepot easy to install and has instructions on how to...good luck..
Jan 05, 2009 | U-Line BI-95
Ice tastes bad even after I changed the filter?
allow your ice maker to dispose old water that is still stucked on its hoses, just throw those unpleasant ices's and water would simply replenishes with a a fres and good supply
Nov 27, 2008 | Refrigerators
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
1,238 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
