Question about Canon imageRUNNER 600 Printer
Canon image runner 600 fuser assy
Does the fuser assy come with all the gears to the left of it, it almost looks like a gear box.
  • 1,219 Answers
No it comes only with fuser assy gears, for drive gears you must order separatley.
Do you need parts catalog?
emma.servis@gmail.com
Posted on Jun 30, 2010
Blurred print of incoming and outgoing report
There are usually two things that can cause blurred printing.
1 The toner/drum needs changing.
2 The fuser assy is worn and not fusing the toner onto the paper correctly. This is easy to check. Does the print rub off the paper with your finger? If so then a new fuser is required. Also its possible a tooth on the gear that drives the fuser is broken. The fuser gear may have also worn down and its jumping on the gear that drives it.
Dec 20, 2013 | Canon LaserClass LC 8500 Plain Paper Fax
Groaning noise
Remove back door & fuser assm, in fuser driving gear mechanism located left side replace 19 teeth gear..see the link for the gear recognition..
http://www.google.co.in/imgres?q=20+teeth+gear+hp+lj+2420&hl=en&biw=1024&bih=605&tbm=isch&tbnid=tMKRhRnWWJRlBM:&imgrefurl=http://stock.esolution.ru/product_info.php/en/bpn-ru5-0957-000cnb-gear-tooth-for-fuser-drive-assy-p3005-m3027m3035-p-46181&docid=VWld5AKGICkrIM&w=640&h=480&ei=Y0x4TpjmLoXZrQeEpt2wCw&zoom=1&iact=rc&dur=356&page=4&tbnh=118&tbnw=176&start=50&ndsp=15&ved=1t:429,r:2,s:50&tx=138&ty=55
Sep 20, 2011 | HP LaserJet 2420 Printer
My Laserjet 5SI printer has been jamming a lot lately and now it's making a grinding noise. Should I replace the cartridge or what?
Fusers generally make grinding noises more than cartridges do. If your paper jams are in the fuser area, check the fuser first.
When you open the left side door of the printer, the fuser is installed on a shelf near the top of the cavity. To remove the fuser, grasp the left and right blue fuser release handles and rotate them to the straight up and down (vertical position. Then lift up on the fuser and remove it from the printer.
Take a close look a the at the gear located on the top left corner of the fuser - does it have broken/ bent teet or is it loose on its mounting shaft? If so, that's probably causing both the paper lams and the grinding.
Also look in the printer directly under where this gear would be if the fuser were inserted in the pinter. Do tou see a build-up of fine particles the same color as the fuser gear. If you do that's further proof the the gear is bad.
You can but a replacement fuser at several places - check out www.printerworks.com & you can get one on an exchange basis.
Oct 27, 2010 | HP LaserJet 5si Printer
How to remove fuser from a brothers MFC 8860DN and reset the counter
WRONG! Press 2 and 8 at the same time to reset the counter.
Apr 20, 2010 | Brother MFC-8860DN Printer
Hp 4250 laserjet is noisy and has numerous jams. page count is 137,619 maint kit has 39% left when searching event # 13.05.00 Fuser output paper late jam
Probebly the swing gear assy, this assy is driving the fuser, is defective. This is a common problem with these machines. Replacing the gear assy should solve your problem.
Feb 16, 2010 | HP LaserJet 4250n Printer
Replace Fuser Gear Xerox XC1040 Copier
Call a tech!. You first remove fuser assy from machine. One green screw to loosen and then you figure the trick out to get it out. Then once its out remove cover 2 screws I believe. Remove the lamp gently, you can do this with out unscrewing anything. Then remove the little clip on end of heat roller, simple spread clip and replace gear. It takes a tech about 10 min.
Feb 13, 2008 | Office Equipment & Supplies
Gear Racheting Noise
Not a easy gear to get to, entire side frame must be removed. I always just replace the whole left frame as pictured, but really you only need to replace gear pic at top, like I say not easy, take pics so you know how to reassemble it.
Jan 10, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother 8840 Fuser Roller Gear
You can buy the gear , I always just replace assembly to reduce possibility of later breakdown
you can Purchase gear or Fuser HERE
Dec 08, 2007 | Brother MFC-8440 All-In-One Laser Printer
Fuser Gear Md No. LJ 7416
You will need to purchase these gears from a brother dealer but I warn against just changing the gears you mention, fuser driver gear in printer frame will be ok unless chipped, but usally the big gear on the fuser goes as does a little white one next to it, and these are breaking becase the fuser is hard to turn, if you just change the gear, the fault will reappear after a little use, best bet is to replace fuser assy (approx $150)
Oct 27, 2007 | Brother MFC-8840D All-In-One Laser Printer
Canon imageRUNNER 600 Printer Logo
97 people viewed this question
old marine
old marine
