Question about Char-Broil Commercial Stainless Steel Grill
Char Broil commercial grill won't heat pass 300 degrees
I have had my 50000 btu grill for less than 2 months. It's just not heating up like I thought it would. How hot should this grill get?
  • 2 more comments
  • Anonymous Aug 24, 2008
    Try to get meat done. Now friends suggest we go out to eat.
  • tedalank May 11, 2010
    I just got off the phone with Charbroil because my brand new infrared does not indicate more than 350F! (should be around 600).
    They are having a recall on defective thermometers......
  • Anonymous Mar 16, 2014
    my char broil grill will not ignite theres no spark
  • Anonymous Mar 21, 2014
    0503219
The new regulators gas grill made to prevent flair ups when lit. Start with just one knob to lite it wait 3 min put on 2nd burner on low. feel the regulator if it is very cold start again after it warms up. if it is just a little cold warm it up by holding it and turn on the last burner
Posted on Jul 08, 2008
I had a similar problem and thought the propane kept running out....come to find out it was a defective regulator. $21 at the local ACE store as running to LOWES and trying to get a point across to a 17 yr old summer help college kid for a intermittent problem seemed more challenging then it was worth. Would barely light the burners and would not get over 200 degrees. Ripped it apart...blew through all the orfices including the regulator put it all back together and would work for a while then fail again. Good luck!
Posted on Jun 02, 2008
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
The burners are not putting off good heat/flame. the temperature is oonly getting to around 300 degrees. what can be wrong?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 30, 2010 | Char-Broil Performance 463463006
New Char Broil gas grill heating issue
Did the kit come with NG orifices and did you use them.
Jun 23, 2009 | Grilling
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
Need help smoking briskett on Char Broil Grill with smoker box
wood chips in the fire box. very low heat. around 200 degree.
maek sure the wood chip is wet and produce smoke. you need to monitor this through out the process.
briskette in the grill side without any heat. depends on the sixe and the thnikness of the meat, you need approximately 12-20 hours before meat become tender.
here are few web site you can get some information
http://www.smoker-cooking.com/howtosmokeabrisket.html
http://bbq.about.com/cs/brisket/a/aa111503a.htm
http://www.wyntk.us/food/smoking-brisket.shtml
http://www.bbq-fyi.com/how-to-smoke-brisket.html
May 29, 2009 | Char-Broil CharBroil 4637318 Grill
Heats only to about 350 degrees
how old is it may neet to clean and blow out burners
May 25, 2009 | Char-Broil Performance 463463006
Char-Broil Commercial Stainless Steel Grill Logo
2,241 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
