Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
88 inch motor will not run properly.
Front cylinder wont run.plugs
front cylinder wont run .plugs-wires were ran fine .as i was riding the front cylinder lost power as if a plug fouled.motor is fresh-compression is fine.i looked for a short and thought i fixed fuses are blowing.motor has a carb not has a crane fireball hi-4tc performance ignition. I WOULD BE GRATEFUL FOR ANY HELP money is tight and this is my mode of transportation until our car is repaired after being hit by a hit and run driver...THANKS FOR ALL!!! ROBERT BRADY!!!!!!!!!!!
  • mooseatk Jul 07, 2008
    Same but back cylinder not firing
I isolated the wiring-- checking for a short or shorts .found the short of all places in the light switch.then one by one went through the ignition system. took the cover off the coil @#%$^@~ the coil blew ...was split at the seam on top .I tried a shortcut by asking if anyone had this problem before .I appreciate the suggestions but had to as usual find and deal with it myself. ONCE AGAIN THANKS FOR ALL..FIXYA IS A GOOD TRIP FOR US TO PASS ON OUR PROBLEMS AND SOLUTIONS HAPPY-RIDING-TO YOU-ALL!!!!!!!! LOVE,RESPECT,!!! " BIG RED ONE "
Posted on Jun 11, 2008
    Problem Solver:
  • 9 Answers
Is the front cylinder firing? put a spark tester on it or pull the plug and ground it to the motor head or something and roll it over and see if it fires. If not then chances are the ignition is bad.
I have a 2003 Harley Davidson 1200 sportster,
Cab or injected ?
If carb looks like an leak at the Oring manifold .Try to start and spray any carb cleaner to the manifold close to the cylinder ,.any change on idle would be an air leak!
Oct 06, 2014 | Harley Davidson Motorcycles
I have a 2002 HD 1200 Custom Sportster and I have lost compression in both cyclinders at the same time. Rode the bike and it ran fine. 2 weeks later I got on the bike and started it up and one cyclind
Changing spark plugs will not affect compression unless you put in the wrong reach plug and it hit and damaged a piston. Sounds more like stuck valves, bent pushrods, broken rockers, or cam drive problems.
May 27, 2014 | 2002 Harley Davidson XL 1200 C Sportster...
I have a ktm 250 sx 2-stroke. It has a new piston and new cylinder. bike ran great before it needed the repairs. Cranks on first kick. Run good but it leaks the pre-mix everytime i ride it and it won'
Where is it leaking from? If its leaking, that's more than likely why it doesn't run right, the fuel/air mixture is off. Also, I wouldn't continue to run it until the leak is fixed as it may damage the motor from not lubricating properly.
Aug 14, 2013 | Motorcycles
I have a 99 ktm 250 sx. Had to get cylinder replated and a new piston. I put the bike back together and oil was leaking from the front lower end of the cylinder and i wont idle. Took the bike back ap
If there is a leak in the head gasket it will never run properly. Maybe the carburetor is plugged if it has sat for a while. The gas/oil mixture can go bad over time. The leak could be from a loose gas line. Or possibly even oil dripping from the oil filter if you just cleaned and re-oiled it.
Aug 10, 2013 | Motorcycles
2000 VZ800 marauder runs mostly on one cylinder
It seems there is too much of fuel going into the non firing cylinder thus the blackish spark plug, recheck the float level to that carburater and also check the valve clearance.
May 01, 2013 | 2000 Suzuki VZ 800 Marauder
1991 suzuki intruder 1400 starter cranks strong but won't start
the battery will build up calcium and wont hold enough kick charge to start bike thou the battery will test ok in this instance,, this happens when a bike sits for a while without a start
hpoe this helps
May 29, 2009 | 1991 Suzuki VS 1400 Intruder
2001 Suzuki Intruder 1400 WONT START!!
Sounds like you may have fould plugs replace with new NGK's. If still no start ckeck spark. two old plugs taped together or even tach welded together makes excellent spark check tool. No open cylinder no shot of air fuel mix to light by plug to fin method (electodes aposing each other) plug two cylinders plug wires and turn motor watching for spark and color of spark.
Feb 08, 2009 | 1991 Suzuki VS 1400 Intruder
Lands Phones Logo
187 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
