Question about Husqvarna Chain Saw 20" Bar
I have a Husqvarna 51. It will start but not stay running.
  • 784 Answers
If staying after acceleration, is some air leak from cranshaft sealing. if just staying than check air leks from between cilinder and carburator.
Posted on Mar 18, 2011
Husqvarna problems
If spark is ok then I would say the carburetor is the likely problem or the fuel is not entering the engine. Something like the following instructions might help.
How to Adjust Husqvarna Carburetor eHow
Look at this manual for model 51 carburetor adjustments.
http://www.getsaws.com/PDFs/w9600001.pdf
Aug 06, 2014 | Husqvarna Chain Saw Models 51, 55
Husqvarna problems
If you machine was not running for some time, the carburetor membrane must be replaced, even if all looks fine. Get a kit and replace all.
Jul 29, 2014 | Husqvarna Chain Saw Handle Models 50 51...
Husqvarna 51 file size
Several bar and chain combinations fit the 51 model saw. If your saw runs an H46 / H80 or H81 style chain you will need a 7/32" (5.5 mm)
If you are running a H21 style chain you will need 3/16" (4.8mm)
May 02, 2014 | Husqvarna Chain Saw Models 51, 55
How do I adjust the air gap on the ignition coil
The best way is with an air gap tool. Most Husqvarna saws run a 0.3 mm or .012" air gap.
May 01, 2014 | Husqvarna Ignition Coil 55 257 245 51 254...
Husqvarna 55 chainsaw has a problem running on idle
start by checking all ur fuel lines for holes then proceed to clean or rebuild ur carb the ethonal in fuel is cloging small engine carb jets and making needles stick so then adjust ur carb back to factory settings try with new air filter as well and run 89octane or higher in your two stroke motors u will c a great differance in performance
Dec 13, 2012 | Husqvarna Chain Saw Models 51, 55
The Husqvarna chain saw models 51 and 55 does not starts.
Is this about two different chainsaws? You will need two different posts giving the particulars about each saw.
Sep 15, 2012 | Husqvarna Chain Saw Models 51, 55
I have a scored piston in my Husqvarna 51 chainsaw. Can I hone out the cylinder and still use it?
You can do that. But it would not run as good or as long as it would buying both the piston and the cylinder housing. You either have to buy both or the try installing a new piston with new rings in it. It should give you enough compression to start it up. But it can't be guaranteed to last too long.
May 29, 2012 | Husqvarna Chain Saw Models 51, 55
What should the H, L, and T settings be on on a husqvarna 51 chainsaw?
the "H" is the high rev setting the "L" is the low or tick over setting and there set up when the engine is hot and running,,,first the high rev ste up tweek the screw till the engine is running at full revs then tweek the low revv till the engine will stay ticking over,,,
Nov 28, 2010 | Husqvarna Garden
Husqvarna 235e will not stay running
Take the saw back for warranty service. We have a Husky #435 that had starting problems when new last year--warranty service replaced the ignition module the first trip, then a little later, they replaced the carburetor--it has worked very well since. I suspect that Husqvarna has had problems with our ethanol blended fuels. Hope this helps!
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 51 from 1991 too much resistance to starting attempts
It sounds like it's sorta gummed up from old gas residue. You could spray carb cleaner in the spark plug hole and into the carb while holding the throttle open and pull the cord several times and then follow that with penetrating oil to re-lubricate the engine. You're probably going to have problems with the carb also. I would have it rebuilt or, better yet, purchase a new one
Jul 01, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
153 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
