I'm having problems getting my grill out handle light to work. There is no information or diagram in my Summit 670 series manual describing the battery installation and how many batteries does it take. Please help me out. Murray
Here is how, check this link from Weber: http://www.weber.com/help/manuals/pdf_files/weber_instruction_pdf_files/GrillOut_HandleLight_178712_62159.pdf
Posted on Nov 23, 2010
How do I light the rotisserie infrared burner?
Nice unit. I was looking at it last night in Home Depot.
http://www.weber.com/grills/series/summit/summit-s-470
Should spark ignite like the burners surely? Perhaps the igniter post needs adjusting, or a lead has become disconnected?
Aug 12, 2015 | Weber Summit S-470 Liquid Propane Grill -...
Hello. I have Weber Summit 670 NG and I would like to convert it to LPG. I was told that it can be solved if I replace the NG Orifice with LPG Orifice. Is that true ? Where can I buy the LPG Orifice...
Ronni, unfortunately none of the Weber grills are approved for conversion from one type of gas to another. Each grill is tested and approved for it's specific gas type. Based on that, converting it, places all the liability on you, if something should go wrong. In addition, it takes more than just the burner orifices to convert a grill safely. With any gas appliance, always err on the side of caution and safety.
Thanks for choosing FixYa.
Sep 12, 2011 | Weber Summit S-670 Gas Grill
Disengage the quick release gasline coupler
If you're attempting to disconnect the hose connection, pull back on the outer sleeve of the Female connector side and pull the male connector out. Be sure the inline gas valve is turned OFF before attempting this.
Hope this helped and thanks for choosing FixYa,
Aug 26, 2011 | Weber Summit S-670 Gas Grill
I can't get the termperature over 400, used to work great, now is slow to heat up and doesn't get nearly as hot as it did the first three years or so that I had it. (Weber S-670 NG). Any...
James, the problem is that the grill's regulator is partially locked up or you are low on gas. Check the gas level firs. If that checks out OK, do the following.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Aug 08, 2011 | Weber Summit S-670 Gas Grill
Just bought summit s 670 natural gas 89208 grill. Bought a display model because it was the last one they had. It was already assembled, so I took it home as is. Everything works great - except....the...
To determine if it is the switch, remove the wires from the back of the switch and touch them together, if the lights come on, it is the switch. You will have to contact Weber for a new switch.
Jul 17, 2011 | Weber Summit S-670 Gas Grill
I just received my two summit genesis grill out handle light. I haven't installed the unit onto the grill handle until I know the light unit works.So, I installed brand new batteries and tested the...
If the batteries came with the lights, they in fact may be dead. There's no way to know how long they have set on a shelf in a warehouse, somewhere, before being shipped to you. Try new batteries and be sure they are facing the right direction and all the positive and negative ends are aligned properly.
Jun 24, 2011 | Weber-Stephen Products 2 each Weber Grill...
Grill was moved slightly. Now won't start.
Motion sensor inside spiffy new fangled gas bottle tripped. Shut off the gas and remove the bottle.
Open all gas control valves on the the grill and close them all making sure they are all off. Reconnect the Grill to the gas bottle and crack open the gas slowly about a quarter turn only. Light that puppy and party on.
May 08, 2011 | Weber Summit S-670 Gas Grill
Summit 670S Natural Gas - Takes several attempts to ignite each burner. Even after holding each knob in the on gas flow position for several seconds to allow for the proper gas air mixture to take place.
Pipe Guy, You need to remove the burners and clean them throughly and the venturi valve on each burner. Spiders love to build nest in them. That should correct the gas to air ratio.
May 03, 2011 | Weber Summit S-670 Gas Grill
Where can I get a wiring diagram for a Weber Summit Sliver B?
Go to weber.com you can down load manuals and schematics for your grill.
Jun 05, 2010 | Weber Summit Silver B Grill
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
