Question about Kenmore 43142 Front Load Washer
Washer door gets stuck and wont open after washing. Have to pry the door open. Eco Cycle Model # 417 43142200. I believe the latch is not releasing the door.
    President:
  • 1,554 Answers
You have to replace the door lock and switch assembly which is part number 131763202. Your machine is made by Frigidaire so check out the procedure here.
Replacing the Door Lock and Switch Assembly on a Frigidaire/Frigidaire-made Front-Load Washing Machine
Posted on Oct 10, 2010
We have a dometic wmd1050 front loader washing machine in caravan we did some washing today went through washing cycle ok lights went out on door lock but can't open door how do we open door
The latch assembly broke so you will need to use a screwdriver to manually release the latch. It will not be easy to get the door open, you will need to get in behind the latch and pry slightly to the left. The parts breakdowns are available below so you can see what you are up against. See the 4th page at the URL below.
http://caravansplus.com.au/pdf/WMD1050-Spare%20Parts.pdf
Apr 17, 2017 | Washing Machines
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our Samsung J1455AV door won't open, just over a year old. Have cleaned the filter, re-run a cycle, turned off at wall. Help!
Hi
Thanks for using FixYa. To start with if the door lock is stuck and wont unlock then you can pry it to open, and just don’t try too hard. The issue can be with the door latch that is stuck, to unlock it you can stick a flat screw driver behind the door latch and then lever it to open so that you don’t have to pry it to open. Once it’s done, please make sure to replace the door latch assembly to avoid any further issues. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 12, 2010 | Washing Machines
Door on WD420 will not open
There is an electrically controlled lock on the door that prevents opening while the machine is in operation, and sometimes for a short period after a cycle has finished.
Sometimes this lock can get stuck and requires some persuasion to release.
This may sound odd but try it:
Make a fist with your hand and bang the door, near the latch, with the side of your fist. Do this firmly, but obviously not so hard that you will damage the door or, more importantly, your hand. This can often release the latch that should have released automatically.
Apr 07, 2010 | Hotpoint Aquarius WD63 Front Load...
Washer will not open after washing cycle ie
Hi:
There is a door locking mechanism that won't let you open the door during certain cycles, and it might be hanging up. After the next time the door sticks, try gently tapping on the door , near the latch area. If the door releases, you need to get that solenoid replaced,
Nov 03, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Sliding door problem
You probably have a burnt out door lock soleniod, it's part of the latch, stuck in the locked position, you have to pry the latch from the inside, to release the catch, just replace the latch when done. GOOD LUCK, RDJRP
Oct 02, 2009 | 2005 Dodge Caravan
MAYTAG NEPTUNE DOOR LOCKED WILL NOT OPEN!
The comment posted 14 may 2009 it what helped me. DO NOT PRY OPEN the door. Find the release cord inside the soap dispenser,,,you may have to remove the 4 screws and lift it from the washer like i did. I had to lean into the door and pull the cord to release the lock. It was not a system error. The washer was over loaded and although the door was closed and locked...the load pushed the door enough to indicate that it was open and would not wash. After opening the door, rearranging the load and removing some, the door closed and latched locked and was able to continue with the wash. DO NOT PRY OPEN,,,use the cord release first,,,this worked for me.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door won't open
you can take the 4 phillips screws out of the corners of your soap dispensor, the lid of the dispenser willlift up and youll see wrapped around in there eitehr a floresent green or orange plastic wire. that is a manual release cord for the latch assy. this will allow you to get your clothes from the machine, form there look into why the latch never released
Nov 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Broken door
You probably have to bad door latch. its easy to replace. it requires i believe a number 20 torx bit you have have to remove the spring around the door boot and then you can put you hands to inside the unit to remove the latch.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 43142 Front Load Washer Logo
126 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
