Question about Honeywell (CT62B1015) Baseboard Heater
Bought new thermostate. furnace kicks on. runs for awhile. have to touch the ignighter to start, furnace is about 30 years old. replace circulator and ignighter about 8 years ago
  • Honeywell Master
  • 2,557 Answers
Check connections to igniter could be loose or it is out of postion , or may be needs replacing again
Posted on Oct 10, 2010
I have installed a wood burning furnace and was hoping to run the blower on my goodman gms80703an and thermostat without having to ignight the gas furnace
If I am understanding you correctly, you are just wanting to circulate the air with your gas furnace and heat the air with your wood burning stove. You should be able to set the fan switch to the ON position and leave the heat/cool/off switch in the off position.
Nov 29, 2015 | Goodman Heating & Cooling
We have a Coleman Electric Furnace Serial # AOL6042086, Model # AHP36C3XH21A and the fan runs constantly, will not shut off. We have replaced the thermostat and just replaced the control board. We h
I wish I was a furnace expert but I will give a push in the right direction. When a gas/electric fan runs it has two speeds. When you turn on the FAN ON switch it should run at the slower speed. If it doesn't turn on or turn off again when you turn it back you have a wiring problem or a thermostat problem. Make sure the thermostat is compatible with your unit and wired properly (on both ends). The other time the fan runs is "in session" when heat or cooling is applied to the system. It should run until the system finishes the cycle then a bit more (30 seconds or 1 minute) to blow the treated air completely through the ducts. If it doesn't stop then you may have a bad fan time delay or relay. Check parts for your model and various appliance repair site online.
Nov 25, 2014 | Coleman Mobile Modular Home Electric...
WE live in ND and have an Amana furnace that is 30 years old. We also have a Central air unt. OUr central air unit started coming on today when our furnace kicks on. Can you tell me why, it was 24 deegrees...
That would only really happen due to one of two things.
A bad thermostat.
A stuck relay. If the relay to the AC is stuck closed then it would come on whenever power goes through to the furnace.
This would be rare because very few units had that type of setup.
You can verify the T-stat by removinf the tsat from the wall. disconnect the red, white and yellow wires. Touch red to white.
If the heat comes on and the AC stays off, then your Tsat is bad.
Jan 17, 2009 | Heating & Cooling
Furnace is not turning on
Sounds like you have a bad fan limit. they will sometimes kick on in the summer when the temp gets high enough. now it sounds like it is not working at all. it is usually mounted with a metal square cover over it removing the cover would expose the dial this it what turns as the furnace heats up and kicks on the fan . turning it by hand will check to see if fan will kick on(turn a lttle clockwise)
Jan 10, 2009 | Heating & Cooling
I have a Rheem Criterion II Gas furnace. It is not igniting.  When I switch the thermostat to "heat" - the furnace doesn't not start.  There are 2 green lights - one is one and the other is blinking.  The...
Roscoe007 shouldnt speak unless he knows what he is talking about, as a heater installer i am telling you the ignitor needs to be replaced, the very fact that the ignitor does light for about 30 sec than goes out rules out any issue with the themostat, replace the ignitor!
Dec 13, 2008 | Water Heaters
Furnace won't kick on
Downstream of your fan discharge there is a little plastic assy. most likely that will have a pickup tube and a piece of vinyl or latex tubing attached. First check to make sure that the pick up tube and/or tubing does not have a restriction. If it is clean use an ohm meter to read resistance across the switch to verify it is operating.
Nov 15, 2008 | Intertherm Heating & Cooling
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
Honeywell (CT62B1015) Baseboard Heater Logo
63 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
