Question about EdgeStar AP10000HW Portable Air Conditioner
How do i recharge my air condition, and where do i charge it.
Cant find right valve to recharge AC top or bottom? 95 oldsmobile cutlass supreme 3.1
on the WEB:
  1. How to Charge the Air Conditioner on a 1994 Oldsmobile ...
    www.ehow.com > Cars A 1994 Oldsmobile Cutlass' air conditioner can be recharged at home, with no need to ... The high side connection port is meant for maintaining air conditioning ...
Jul 20, 2015 | AC Cars & Trucks
I am trying to locate the correct port to use to recharge my air conditioning system?
The port in the larger of the 2 AC lines from the compressor is the port you charge at.
May 27, 2014 | 2005 Suzuki Reno
Air conditioning
Have you tried to recharge it with some r-134. It could be so many things things if it won't take the charge. Does your compressor turn on? I just flipped a coin (heads) so it's definitely the orifice tube.
Apr 18, 2014 | 1998 Ford Expedition
98 Grand Cherokee air conditioner won't blow cold air after recharge
It sounds like your blend door isn’t operating correctly . The blend door simply is a flap that is designed to close off heater core when it’s calling for A/C , and opposite for heat . Check to see if it’s operating
Jan 17, 2018 | Cars & Trucks
Recharge the air conditioner
Instructions
    • 1Start the recharging process with any left over freon you may still have. Open the Civic's hood and attach the kit to the Civic's low side port. Then, set the kit onto a place in the engine compartment where nothing can move or shift once the engine has been cranked.
    • 2Start the Civic and let the engine run until it reaches its normal operational temperature.
      • Single Pressure Gauges for Indl., Commercial & Specialty Uses
    • 3Turn on the air conditioning to its coldest and hardest-blowing settings. Place a thermometer into one of the Civic's air conditioning vents and monitor how the temperature drops. Once the air conditioning's temperature reaches a level, constant degree, remove the thermometer.
    • 4Open all four doors on the Civic. This will allow any colder air generated to escape, and this will keep the Civic's air conditioning for accidentally cycling off while you recharge the refrigerant levels.
    • 5Turn the recharging kit's valve all the way down and let the refrigerant charge into the Civic's air conditioning periodically, shut the valve and look at the kit's gauge. This will allow you to monitor the recharging process. Allow at least one minute to elapse between refrigerant charges into the system.
    • 6Shut the valve of the canister, once it has become depleted. Disconnect the kit from the low side port.
    • 7Detach the hose, gauge, and valve from the empty canister and attach them to a new canister of refrigerant. Reattach the kit's hose to the Civic's low side port and continue recharging the system, allowing a minute between individual charges. The can itself can potentially grow very cold and hard to hold, even with gloves. Should this happen, wrap the can in a towel warmed in water. Ring out excess water before wrapping the canister.
    • 8Place you thermometer into one of the Civic's air conditioning ducts. Keep an eye on the falling temperature within the Civic's air conditioning system. The system is charged when the temperature hits 40 degrees. Also, within the engine compartment, the Civic's air conditioning aluminum tubing become uniformly cold.
    • 9Shut the recharging kit's valve and remove the kit from the low side port, once the system has been successfully recharged. Shut down the Civic's air conditioning, turn the engine off, and remove your key from the Civic's ignition. Also, shut all the doors
Jun 21, 2012 | 1998 Honda Civic
Air condition does not work just hot air I have set it to auto or manul it just give me hot air
Your freon level is low. Go to any shop that charges car air conditioners and get your freon recharged. Usually the charge is around $25-50. Joe
Mar 16, 2010 | 1998 Lincoln Town Car
Air Conditioning needs recharged
Ok this port for charging in the pipe thicker tries to recharge the system with a UV dye that this is where you said because if you drain your A / C because it has no gas is leaking
Aug 18, 2009 | 2005 Dodge Neon
The air conditioning need to be recharged. Where can I take it? I have a jeep cherokee 2001 limited.
Just about any AC company will recharge your unit but remember if you need to charge it There is a leak. Russ
Jul 19, 2009 | Friedrich QuietMaster SS12L10 Air...
AC is not working
Sounds like the A/C system just needs to be recharged. When was the last time you had this done? Just take it in to your mechanic and he can do it for you and if that's not it for some reason, then he will be able to find the problem but most likely you need more freon added.
Benjamin
May 26, 2009 | 1995 Acura Integra Coupe
Would like to recharge my air conditioning on my 2001 nissian maxima that has 117,000 on it blows hot air when air conditioning is turned on.
You will need R134a, and a filler hose. Charge the system on the low pressure side, it should have a blue cap on the charge point.
Your filler hose will only fit the low pressure side, just in case the cap has been removed.
May 23, 2009 | 2001 Nissan Maxima
EdgeStar AP10000HW Portable Air Conditioner Logo
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
