Question about Culligan Sediment Water Filter Heavy Duty
Will not stop regenerating water keeps running
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
What model is it? If it is running to the drain it is most likely stuck in backwash or rinse cycle. We need more info to help.
RJ
Posted on May 14, 2011
Water softer regenerating too much can that consume excess water?
it uses a set amount of water during the regeneration process
if it regenerating more often than necessary , then- yes-more water will be consumed
does it need to do it so often , well that will depend on the water hardness readings
If you have it connected on a mains water supply from the council water works , then regeneration would be set at around 10,000 gallons but at each regeneration the same amount of water is used as if it is regenerating at 1000 gallons
Sep 09, 2017 | Water Dispensing & Filtration
How often should my softener regenerate
the regeneration period is set on the water consumption
after a set amount of water is used , it should regenerate automatically
use quality water filters prior to the softener to remove mud and particles that all affect the regeneration process
regeneration is the process of removing the elements that have been collected in the machine and to replenish the salt content in use
Sep 07, 2017 | Culligan Measuring Tools & Sensors
Harveys water softener leaking
Actually it is regenerating if it is filling the salt tank with water. It is just not drawing out the water/brine during the brining cycle. Check the eductor assembly it is most likely plugged with iron or debris. Clean thoroughly and manually cycle unit to brine draw. Usually second cycle, until the water level is back to normal then do a manual regeneration from beginning. Then regen 3 consecutive days.
Feb 05, 2014 | Reliance Water Dispensing & Filtration
My water softener emptied im not sure how long it was empty for but I dont think it was too long I filled it with salt and now it doesnt work. It still regenerates but im getting hard water still any...
Do you mean the salt tank was empty? If so fill salt tank half way wait about 6 hrs for brine to develop. Manually regenerate softener 2x within 24 hrs. When the salt runs out the resin becomes saturated with hardness minerals. It takes at least 2 regeneration cycles back to back to completely restore soft water. Also the hot water will take some time to get soft. It will help to flush water heater after cold water is consistently soft.
I hope this helps,
h2oservices
Feb 26, 2011 | Culligan Compatible S7011C RS23SED5...
How do I increase or decrease regeneration frequency?
Water filters do not have a regeneration cycle, they filter the water as it passes through. You do have to replace the filter and the frequency of doing that depends on the sediment in your water. If you are talking about a water softner which does regenerate, all the new ones have sensors in them and they regenerate only when needed. This saves tons of salt over the old systems you would set to regenerate every two or three days whether they needed it or not.
Sep 10, 2010 | Culligan Sediment Water Filter
Hard water, salt in in tank, what do i do
Make sure there is not a "Salt Bridge" in salt tank. Salt tank should always be at least 1/2 full of salt.
You may have just run out of soft water, run 2 manual regenerations in 24hr period. If no soft water still. The eductor assembly is plugged with iron or sediment and needs to be cleaned out. The eductor assembly is where the brine is drawn through to regenerate the resin.
RJ
Aug 12, 2010 | Culligan Sediment Water Filter Heavy Duty
Where to put the salt? and how to flush it? thank you wg844
Dump the salt in the separate brine tank. Always keep salt/brine tank at least half full. If you want to run a manual regeneration push the regen button. For delayed regeneration (2am) push once, for immediate regeneration push twice.
RJ
Aug 09, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Culligan Gold series softnerdrain line runs constantly in street.
The main piston/sealpack is frozen up and needs to be replaced. There is a retrofit kit available from Culligan to repair this issue. The reason it stops when bypassed is the water is shutoff to unit.
RJ
Jul 25, 2010 | Culligan Sediment Water Filter Heavy Duty
Check the units drain filter. If clogged up it will make this unit run constantly
Jan 24, 2010 | Culligan Sediment Water Filter Heavy Duty
Pool filter return keeps stopping
If you have cleaned the fingers in acid you may have to replace the socks on the fingers.
Jul 21, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Culligan Sediment Water Filter Heavy Duty Logo
296 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Dan Connors
Dan Connors
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
