Question about Brother CS-100-T Computerized Sewing Machine
Brother CS100 I can turn on the machine, but the end wheel will not turn. If I try to use the presser foot the machine makes a terrible noise. Please Help, Susan
  • raskmc Jun 03, 2008
    the wheel turns hard after doing this, but it turns then the needle hits when it tries to go into the bobbin area, what now??? Help
  • Megan
    Megan May 11, 2010
    I don't know if you are still having this problem, but are you saying the needle hits the bobbin case? If so your machine is probably out of alignment. Take it to a nearby service center, they can fix it in 5 minutes. Here is a site to help you locate service centers.http://www.brother-usa.com/service/
    Problem Solver:
  • 26 Answers
Try to turn the handwheel by hand, with the machine switched "off".
If no success, then remove the bobin case from the shuttle hook, and try to turn the handwheel again.
If it persists not to turn, then remove the shuttle and clean the race, from lints and small threads.
Put everything back in the reverse order.
Posted on May 30, 2008
Brother 834dp, entire machine is locked up??
the best thing would be for the machine to be serviced
Mar 08, 2012 | Sewing Machines
My CS6000i is freezing on sewing over seams and creating a terrible loud sound refusing to sew. it does not give an error message and once stopped it will be like it never happened, however I have to...
At Joann Fabrics you can buy a notion called a Jean a ma jig, it is something that you put under the rear of the presser foot so that the presser foot stays level and will go over the seam easily. Make sure if you use heavier fabric or are sewing on denim use a #14 or #16 needle so that it won't break. Good luck
Jan 28, 2011 | Brother CS6000i Computerized Sewing...
I cant get the needle to catch the bobbin thread. I just received the machine, i might not be doing it write? any suggestions
This has to be done by hand.
Raise the presser foot, then thread all the way down to the needle. Put in the full bobbin with thread end loose and visible. Hold the end of the thread in the needle with one hand and carefully turn the wheel so that the needle lowers and lifts the bobbin thread. Place both threads behind the presser foot. Now you can sew.
Jan 24, 2011 | Brother XL3750 Mechanical Sewing Machine
My brand new machine Brother PC 420 is making a clunking noise as the needle moves as if the timing may be off? What is this?
Make sure that your needle is inserted all of the way up, maybe even install a new one, just to be sure. Recheck your threading, with presser foot up, pull top thread, should pull smoothly, now put the presser foot down, pull again, should barely move. If, you are sewing on a bare table, try putting a bath towel under it. If, noise continues, return it and get a new one.
Nov 05, 2010 | Brother PC-420
Presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Oct 04, 2010 | Brother Sewing Machines
Machine jammed
Turn off the power and remove the needle and presser foot.
Open the needle plate and bobbin case and clean the area, removing lint and the jammed thread.
Make sure the bobbin case is properly in place.
There is a maintenance section in the manual to show you how to remove the bobbin case and clean the machine.
Install a new needle with the flat side to the back of the machine.
Rethread the machine with the presser foot up.
Make sure the thread from the bobbin is feeding from the bobbin spool in the correct direction and through the proper guides.
If you need a manual, you can download one at Brother.com.
Mar 10, 2010 | Brother CS-8060 Computerized Sewing...
My brother CE 4000 sewing machine freezes. After some tinkering I can sew a little then in happens again. It makes a shuddering noise then freezes and shows an E6 error message?
Remove the needle plate, bobbin and bobbin case.
Clean the shuttle and surrounding area.
Replace everything.
Make sure the flat side of the needle faces to the back of the machine.
Raise the presser foot and re-thread the machine.
Mar 06, 2010 | Brother Sewing Machines
The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Apr 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
CLICK AND GRIND IN 270D BROTHER SEWNG MACHINE
Make sure you're using the correct foot for the stitch. Is this during sewing or embroidery? Take off the bobbin plate using the screwdriver and remove the bobbin. Make sure everything is clean under and around the shuttle. If you've ever broken a needle the tip might have fallen down into the mechanism and occasionally be jamming it.
Nov 19, 2008 | Brother SE-270D Computerized Sewing...
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother CS-100-T Computerized Sewing Machine Logo
171 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
