Question about Kohler Miller 907209 Bobcat 225 Welder Generator
My welder will not idle down-auto govenor not working
Why will it not rev up
Welder Idles but dosnt rev up so when i strike an Arc [Archive ...
www.hobartwelders.com > ... > EQUIPMENT TALK > Generator/Welders
Apr 21, 2008 - 7 posts - ‎4 authors
... is good there,I have continuity from the wire there back to the Auto Idle Module,and i... If it does not affect the idle. then check these things. ... out,,can i put a PTO cable on the throttle and pull up the RPMs when i weld? right ... Benefits of Stick?
Sep 26, 2007
SA 250 will not strike an arc
May 7, 2006
Lincoln Weld-Pak 100hd.. Need some opinions, =]
Jan 15, 2005
Aluminum repair
Mar 19, 2003
More results from www.hobartwelders.com
SA-200 Idler Troubleshooting - Weldmart Online
https://www.weldmart.com/main/.../sa200idler_troubleshooting.html
The solenoid pulls the carburetor throttle plate closed and the engine drops to idle ...Turn it off (close it) and the solenoid releases; the welder idles up. ... If it does show power-with the engine off, remove the wire and recheck the terminal. ... B. The idler solenoid is good but it will not idle up when you strike an arc, or when a ...
Idler control for sa 200 lincoln welder - American Welding Society
Dec 08, 2015 | Welding Tools
What is wrong with the idle on my welder? the switch works , it idles up when I switch it on high and it idles down when I switch it down but it wont go up when I strike an arc or use power tools, what...
There is something wrong with the auto load sensing switch which is part of the generator. That is the sensor that detects when current load from the generator drops as in when you strike an arc or turn on a power tool and cranks the throttle to full power. It is obviously working on manual because the manual switch is cranking the revs up so the solenoid that operates the throttle is ok. My advice is to take it to a service centre that deals in welder/generator sets as you are playing with dangerous voltages and may possibly damage the machine by tinkering with it or fry yourself (nasty)
Jun 27, 2014 | Lincoln Ranger 250 Gxt Welder Generator...
Terrano diesel 1996 auto transmission starts in the morning but stalls when put into gear. It won't work until after 5 minutes at idle after which time it seems to work. Have had the diesel injec
try a new fuel filter if you haven't replaced it already. you may have a weak injection pump; does it crank for a long time before it starts?
Apr 06, 2013 | Cars & Trucks
1988 CHEVY S-10 PICK UP IDLES HIGH
Peck on it with something to see if it idles down, if it does you probably need a new idle positioning sensor.
Jun 24, 2012 | Chevrolet S 10 Cars & Trucks
Hi, i have a lincoln 300D welder and the problem is when I have it on auto/idle it wont work. it only weld when I have on high/idle. please help. it a 2006 lincoln 300D classic with a perkin engine
You can try to turn the screw on the carb to slightly raise the idle and see if that makes a difference. If not then there is usually a type of inductive pick up that has part of the wiring going through it. When it sense a current draw it releases the engine from low speed. Some of these set ups don't work well if the idle is turned down too far so that's why I suggested trying that first. Plus is that works it is a cheap repair.
Jul 20, 2011 | Electrical Supplies
When idle down switch is turned on you can see the solinoide move the govenor lever to idle down but too much so the engine shuts down. how do you adjust the idle down?
Hello, generally there is a screw on the carb that when the throttle is being moved to the idle position, this screw can be turned in to allow the engine to "idle" faster. If you could provide the make and model of the unit, this will help to solve your problem.
Feb 06, 2011 | Electrical Supplies
I have a 1949 hobart pipe line stick welder, it has an inline 4 willils jeep flat head motor in it, i am looking for information on how to set up the govenors on the welder
I also have a 1949, Hobart Welder. I've been watching your post hoping to see if anyone could offer help with parts. I was wondering if you have found parts of this machine. If you have please post where the parts are available. I don't know what engine is in my Welder. I know it's a four-cylinder flathead motor. The gas tank as a whole and the idler doesn't work. Please post
Dec 04, 2010 | Garden
Auto high idle lincoln ranger 8
Had the same problem a couple yrs. ago . Took it to the repair shop turned out to be a diode or transistor type thing less than 50.00 to fix.
Apr 29, 2009 | Lincoln X2688 2 YR EXTENDED WARRANTY FOR...
Engine won't run smooth for longer than 5-7 mintues
The throttle control board is not working corrctly
Mar 12, 2009 | Welding Tools
Kohler Miller 907209 Bobcat 225 Welder Generator Logo
406 people viewed this question
Top Kohler Welding Tools Experts
Bill Boyd
Are you a Kohler Welding Tool Expert? Answer questions, earn points and help others
