Question about Whirlpool Dryers
Dryer will not start unless I roll tub by hand . Model Ler7648kqo
  • 525 Answers
Start winding is probably bad in the motor. Remove the drum belt and try starting it. If it just hums with no load, replace the motor.
Dave E. (Illeagle)
Posted on May 31, 2008
Dryer
You need to check the belt around the outside of the tub that turns the tub, the tention pully and the motor. is the belt broke? loose? motor turning?
Aug 17, 2012 | Dryers
My kenmore oasis dryer model #110.67062600 does not want to start when i pressthe start button
if the drum rolls freely, put your hand inside and pull the drum around, it is probably the timer
Aug 09, 2012 | Kenmore Dryers
How do i change drive belt on zanussi tumble dryer model number td 4112w
take back cover off ... place new belt bottom first then roll it round tub... WATCH YOUR FINGERS.....if no cover on rear undo two screws on lid (rear).....do as stated above but its harder.07779933829 uk
Feb 23, 2011 | Zanussi TD4100W Electric Dryer
Tub on dryer will not turn unless it is spinned by hand several ltimes. When the button is clicked to turn it on, there is a noise that sounds like it is trying to connect, and when the turn is turned by...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Frigidaire Dryers
Overheating
sounds like you may have a plugged up vent or a bad motor. disconect vent hose from dryer and run a load of clothes if it works ok it is the vent. If the motor is shutting off and wont start untill it cools off youneed a motor. somewhere around 175.00 total cost would be a moderate estimate depending on which dryer could go to 225.00 depending on area and company that services.
May 28, 2009 | Dryers
Dryer drum doesn't sart rolling when it is turned on.
It is not using the start winding in the motor. You might be able to remove the end bell and clean the switch?
Apr 24, 2009 | GE DBSR453EBWW Electric Dryer
Gas dyer won't start, have to kick start it.
If your bearing,glides, and idler are all fine then your motor is gone.
You could apply some zoomoil to that motor but you will have to drill some access holes as the manufacturer does not provide any. For $150 bucks a pop I would try a $2 bottle of High temp zoomoil from ace hardware first.Use a 1/6th inch drill bit and do not hit the shaft. The bearing wells are on either side of the motor and you will have to take the drum out to get to the motor. To access the dryer innards open the door and remove the screws holding down the top. Get the top out yer way and remove the front. Get the drum out and clean out the dryer. Send me any folding money you find. LOL You may find enough change in the dryer to buy some oil. Zoomoil is use for HVAC. It is heat resistant and does not disapate. After filling each bearing work the motor by hand till it loosens up. Oil the idler check the slides and the rear bearing for wear.743d531.jpg
Mar 10, 2009 | Frigidaire Dryers
Tub wont and start switch wont hold
Hi! msbjs
Sound like this could be a motor problem. Is there a lot of lint inside the dryer and around the motor?
InMrFixIt
Oct 30, 2008 | GE DBSR453EBWW Electric Dryer
Fridgadare gallery electric dryer
i need the model number on this one some of those galleries were double rotation some wernt now if you hit the start switch and hear an electric buzzing sound open the door hold the door switch with one hand and spin the tub real hard to the right with the other but be ready to jerk your hand back if the motor starts then change the motor or clean the centrifugal switch most of time have to chang the motor when you find out reply to me for detailed instructions on how to do it also the rear tub bearings are bad about going out and jamming the motor 6 years old is about the time so check the tub for rotation first and if you have to do the spin start test be sure to set the timer first ok
Jan 02, 2008 | Dryers
Whirlpool dryer
    You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Oct 22, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
