Question about Kenmore Elite HE4 Electric Dryer
Dryer runs, but when it shuts off after running a load it will not turn back on...no lights, no beeps, I can unplug it for a while,plug it back in and it will run for one more cycle and then I have to unplug again and wait to restart the next load
  • 171 Answers
It sounds to me like it is a sensor that keeps it from overheating and it may be on the blink. If it is getting to hot , you may try looking at the exhaust tube and see that it is not kinked or crushed and it is all straight so it allows the hot air to get out freely. If it is overheating which I don't know if it is you may want to put a bit less articles in it so it dries with less effort....just a thought as I have no idea how you fill your dryer , again just a thought.,
Posted on Oct 10, 2010
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Maytag Epic dryer model MED9800TQ0. Dryer was running fine, changed loads, held the start button down, it beeped and attempted to turn the drum, clicked and nothing. All the controls light up, timer...
does the element come on at this point ?
I'm not sure if you tried this already or not, but i would unplug the unit and wait a min and plug it back in and see if it resets and then works again . you could have had a power surge .
Nov 05, 2013 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
I have a HE3 dryer which will not run and does not light up. I checked power at the outlet and equipment connection and it has power. I then activated the diagnostic test mode and all lights are activated...
Try shutting off the breaker in the main electrical panel for a few minutes. Then turn it back on again. Sometimes resetting the main power will re-set the programmable Logic Controller.
Jan 09, 2012 | Kenmore Dryers
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
My dryer was working of I have to say never really has dried as well as I thought it should but it was at least working. However now it will not turn on at all. It was at first just beeping and all the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2010 | Kenmore Elite HE4 Electric Dryer
The machine lights are blinking and it is beeping?
First try unplugging from the wall leave unplugged for 5 mins, and plug back in, this may fix it.
Mar 26, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a FEQB4000FSO dryer that continually beeps, running or finished. The lights flash and I can't reset it...HELP! it makes me crazy!
first see where the beeping is coming from you might have a load finish alert setting on your dryer as in when it finishes the cycle it beeps but the contacts might have gotten stuck together so they are making the noise always try first unplugging the dryer for couple seconds than if that doesnt help  get the wiring schametics its usually on the inside bottom pannel your panel should have two or three screws on bottom of the bottom panel and check on the wiring schametics if you have the buzzer (probably name used in the schametics) if yes than try to see where it is so you can just disconnect it
but easiest thing to do is just unplugg it and plug it back in after 30 seconds
Jun 07, 2009 | Frigidaire FEQ1442ES Electric Dryer
Whirlpool Duet Front load dryer problem
plug it back in and hit the cancel button if there is one on there
Mar 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Dryer makes three beeps but wont start
Check your door closer switch. Mine was doing the same and it turned out to be as easy as changing the switch.
Mar 23, 2008 | Kenmore 62602 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
42 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
