Question about Dell AS500 Sound Bar Computer Speakers
How do i use my sound bar without an actual computer tower?
  • 3,940 Answers
The sound bar AS500 gets it's power from the LCD it is attached to, if you are using a portable, connected to an LCD then you can still use it.
If it is an AS500PA then it has it's on AC power adapter, then you can connect it to any computer.
Posted on Oct 09, 2010
Where is the speaker bar plug on a dell monitor
This plugs into the tower unit sound output. It is on the back of the tower and will have a speaker icon. There is no sound out on a common dell monitor.
Jun 02, 2014 | Dell AS500 Sound Bar Computer Speakers
Sign in from my tower computer to laptop
Hi Monica,
This is easy enough: log out of Facebook on your Tower, go to the laptop, clear the address bar on the top of the screen, type into the address bar, facebook.com and hit enter. You should then be at the main sign in page and able to access Facebook on your laptop. Just remember, you'll only be able to use Facebook on one device, your Tower or your laptop.
Nov 17, 2013 | Computers & Internet
Dell in inspiron 1545 wireless adaptor not turning on
Without knowing your exactyour Operating System, I cannot point you, directly, to your download. I can, however, bring you to the Inspiron 1545 Update Download page. Which is actually a better choice, as it contains all updates and upgrades and firmware for every device in your model:
First: be sure your physical On/Off switch is on. That will either be located on the left, front or right edge of your computer.
Dell also uses the Fn+F2 combination, on some models (without a physical switch).
If you have a Radio Tower Logo on your F2 key; hold down your function key and tap the F2 key (the same Radio image you see on your Fn Key - left of space bar). If it has a circle with a strike through it (Like a no smoking sign) that means your Wireless Radio is OFF.
To turn it ON simply hold down your Fn Key, again, and Tab the F2 key again until you only see the Radio Tower Image, without the Circle Strike Through Image; that means it is On...
**NOTE: Be Certain to minimize ALL windows to see the image when pressing Fn+F2:
1. Select <Operating System> from the drop-down menu on this page
2. Scroll to <Network>
3. Click the + Sign Left of network
4. Choose <Wireless Network Adapter>
5. Select Download Using Browser (if you only wish to do 1 upate).
Thank You For Choosing FixYa~!
Mar 22, 2011 | Computers & Internet
How to remove sound bar AS501
There is a clip near hook by pushing it.It will unlock the bar and slide it to right in horizontal position but in tower position it will slide to left7_22_2012_10_18_04_pm.jpg
Feb 17, 2011 | Dell AS501 SoundBar 2 Speakers
The computer does not fully boot when turned on, and the tower makes a continuous beeping sound. The monitor works fine, the problem is the tower. The tower just keeps on beeping without turning on or...
Hello
That beep could mean alot of things, but probably a VIDEO CARD or RAM has become unseated.
If you feel comfortable with this, UNPLUG THE COMPUTER take off the case, remove and reinsert the ram chips, and the cards. You might need a screwdriver or two, and a LIGHT. The ram tabs are small.
Good Luck
Nov 25, 2010 | Microsoft Computers & Internet
My computer screen is black after logging in and i cant do anything i have windows vista
Hello
This usually occurs when your RAM is faulty and can actually happen to all computers running many different operating systems. Aside from installing a new operating system to test out the RAM, you can simply switch out your RAM.
Turn off your computer if it is on. If you are experiencing the black screen regularly, there is a good chance that it will not allow you to boot up your computer fully without shutting itself down. If this is the case, your computer is already more than likely off. Remove the power cord from the computer tower.
Remove the screws that hold the PC tower cover in place with a screwdriver. The tower cover usually only comes off on one side, so gently remove the side that is capable, and place it away from the tower. Users with laptops need to remove the RAM panel from the underside of the computer. This gives you access to the RAM for replacing.
Locate the RAM that is attached to the motherboard of your computer. You will see clasps that hold the RAM into place, and you may see more than one stick of RAM. Remove all of the RAM sticks by pushing the clasps away, unhooking the RAM from the motherboard. Click your new, replacement RAM into place, and cover the tower back up with the cover, or replace the laptop RAM panel.
Hook up the power cable or place the battery back in, and power on your computer. You now see that your computer is working without the black screen appearing. If you have more than one stick of RAM, turn the computer off, and remove the power cords and battery. Insert one old RAM stick, and cover the tower back up, replace the power cord or battery, and turn on your computer. Check to make sure it does not present you with the blue screen. One by one, reinsert the old RAM sticks into your computer, and test your computer for stability. Once you are presented with the black screen, remove the last old RAM stick that you inserted, and your screen problems are gone.
Nov 14, 2010 | Computers & Internet
I can't get my sound to work
The first thing to check are the speaker plugs. Depending on the options of your tower there could be up to six different plugs on the back of the tower. Usually the green colored plug is for audio out. Also check all the connections on the speakers for anything not plugged in correctly.
Next right click the speaker icon in the task bar. The task bar is located in the lower right hand corner of the display. A small window will open giving you 2 choices. Left click "Adjust Audio Properties". If you cannot locate it in the task bar then left click the "Start" button, left click "Control Panel" then double left click the "Sound and Audio Devices" icon. Make sure the "Mute" check box is not checked.
If you still have no sound then click on the "Hardware" tab on the "Sound and Audio Devices" window and left click the "Properties" button. This will open another window.
In this window under "General" tab check to see if it says "This Device Is Working Correctly". If not click the "Driver tab on this window. You will be given a choice to "Update The Driver" . Clicking this button will check for any updates to the sound driver.
If you still are without sound your problem may be a bad speaker wire or cable.
I hope this helps.
Oct 14, 2009 | E-Machines eMachines Desktop PC
Dell dimension 8400
IT MEANS that the processor is not getting cooled enough, try turning on the comptuer with the side panel open, dont reseat the cooling tower, however also check for the four lights on the back of the tower and post the same,,
Jan 25, 2009 | Dell Dimension 8400 PC Desktop
Spray tower fell off
The Spray tower fits in the bottom rack, Its actually pretty obvious as there is no way it can sit int he position it has to without being in the rack itself otherwise the rack and tower would block each other all the time.
 Examine the base of your spray tower it should have two "clips" or plastic protusions that will, with a circular twist, snap onto the bars of the middle of the rack itself. Then when in place and your rack is slid inside the dishwasher the tower should sit directly over top of the exact middle of your bottom spray arm.
et Voila.
Nov 09, 2007 | Kenmore 24 in. 16309 Built-in Dishwasher
Installing a firewire pci Card onto my HP Compaq dc5000 Small Form Factor PC
Hi, Actually there are various types of customized firewire connections for your computer. Here is a link to view some products that might work with your computer. http://www.firewire-1394.com/firewire-usb-combo.htm Also, there are different sizes of PCI cards available. You have to shop around to find an apropriate size.
May 04, 2007 | HP Compaq dc5000 PC Desktop
Dell AS500 Sound Bar Computer Speakers Logo
205 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
