Question about HP Officejet 5610 All-In-One InkJet Printer
How do you scan photos everytime i press scan it says Error
  • Jaun Aponte Oct 09, 2010
    it says each time i press scan: No scan options Refer to devcice documentation
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
You need to install the full setup of your printer in your pc
use your cd or download it from Hp site in this link
hope i help you
Posted on Oct 30, 2010
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
Canon PIXMA iP 1500 does not print
1 press menu
2 PRESS scan copy scan to enter service mode
3 use > to go to NVRAM ACCESS
4 set ABS-M LEVEL TO 0
5 Set ABS P LEVEL TO 0
6 Set press STOP to EXIT
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
USB NOT CONNECTED ERROR WHEN IT IS CONNECTED
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
May 05, 2009 | HP Photosmart C4250 Multifunction Photo...
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
2200 error on dell 962 all in one printer came on lighted screen. then i powered the printer off and it will not work at all. unlighted screen says power down error
1. Uninstall, and re-install the printer.
Else....
2. Error 2200 is a Scan Carrier Stall error... Maybe the scan carrier stalled during a scan job? Turn off the printer, wait a few seconds, and then turn on the printer.
else
3. If no result....Try this... turn off the printer then remove the power supply and press the power button for 15 seconds (it should clear info out of the printer). Then plug the power back in and press the power button.
Thanks for using FixYa - a FixYa rating is appreciated!!
Re-Post if additional help is required.
Jan 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
Scanning
Scanning Photos With the Control Panel Scan menu, you can scan photos to a file, application, or memory card.
Scan to File 1 Place a photo or photos face down on the scanner glass.
2 Press Scan to display the Scan menu.
3 Press �� or �� to select Photo.
4 Press �� until Scan To is selected.
5 Press �� or �� to select File.
6 Press Start.
The document is scanned and saved based on the Kodak AiO Home Center scan picture settings.
You can change the folder where you want these saved. Just go to tools in your printer window.
Hope this helps- Happy scanning!
Jan 29, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I have an hp f4280 and everything is installed. i cannot get it to scan, everytime i press the scan button the power button goes from being lit to blinking. i dont know what im doing wrong. is there...
The all in one solution software you used in XP doen't work with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP f4280) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Dec 23, 2008 | HP DeskJet F4280 All In One Printer InkJet
Unable to scan from 5100 to computer
sure..hope this is still not the case..some answers might be here
http://tinyurl.com/6qcpgy
May 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
File Error?? Please help
i would just upload all of them to the computer, then clear the camera
Aug 27, 2007 | Samsung Digimax S730 Digital Camera
Error code problem
Unplug printer. Press and hold power button for about 15 seconds. 5C00 is a hardware service code. Meaning there is an EEPROM error on the printer systemboard. Which may need to be replacing by a certified techinican.
Jun 23, 2007 | Canon SELPHY DS810 InkJet Photo Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
