Question about Nintendo Wii Console
Connection problems i find my internet connection it all sets up but when it does the test thing it doesnt complete the connection. can you help please. thanks
  • 31 Answers
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Posted on Mar 05, 2009
  • 3 Answers
If your trying to use a Wireless Router, you might have to deactivate the security firewall the your router has enabled. I had to do this but since I don't know what kind yours is you'll have to call your internet provider ( i.e. Time Warner, etc. ). If your using a regular Modem, you can only have one thing plugged into it at a time. So this means you have to unplug your computer from the modem and plug your Wii LAN Adapter into the modem.
Hope this helped :D
Posted on May 31, 2008
How can i test my internet connection?
Ok. If you have internet at your home already then, what you need to do is go to the main menu where it shows all the "channels" you have. At the bottom left will be the wii options menu click it, go to wii settings, click the right arrow once click internet, click connection settings. Pick which connection you want it doesnt matter which one you pick. So click one and if you have wireless internet click wireless and click search for an access point and your internet connection from your house should show up if not that is something wrong with the router not the wii at all. Save the settings and click ok for connection test if asks for a wii update hit no and then when it takes you back click at the top use this connection and you will be good to go with the connection
Hope I Helped and Explained without issues NoobTerminator aka Manchild
Mar 25, 2011 | Nintendo Wii Console
Playstaion network is not working on my playstation. All my other internet parts are working according to the Internet connection test. How. Can I act against this problem.
Hello mike_mcgill
Try the following steps:
1. Completely power cycle all equipmet before attempting to connect online. To do this, unplug all network devices from their power suppliies, e.g. modems and routers. Wait at least 2 minutes before turning them back on again.
2. You have stated that you have tested your internet connection. How? It may be worth contacting your ISP to confirm everything is working as it should be.
3. What type of router are you using?, e.g. 802.11b/g/n. If you´re using an n, this needs to be set to mixed mode. To find out how to do this, consult your routers manual, or contact the manufacturer via their website.
If none of the above steps work, there are other things you can try, but I will need to know how are you trying to connect to the internet, e.g. wired/wireless.
Hope this helps. Let me know if you require any further assistance. Good luck!
ajblaj
Sep 16, 2010 | Sony Playstation 3 (PS3) Console
Internet
IN your description you didnt say too much of what the problem is your having, but what i do recommend you doing is rebooting your computer, if that doesnt work, you might have your wi-fi turned of, you have to enable it because that is what connects you to the internet,,, if that doesnt work, one last thing i recommend you doing is checking your internet source, your modem, your setting etc.. that should fix the problem.
Jun 04, 2010 | ASUS Eee PC Seashell 1005PEMU17BK 101Inch...
Okay so im trying to use my dsi's internet and it says something (i forget what but thats not it)anyways i got to connection settings and put my password for the internet thing then i go to save and run...
if your using search for acess point it will find your own acess if you put manual setup it has 99% posibility that the error happens if it says no acces point in range move closer to your computer and it may work if it doesnt it means theres a problem with the telephone line so tell a fixer for the telephone line to help or tell your parents
Feb 04, 2010 | Nintendo DSi Black Console
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
Xbox 360 not connecting to internet
Just go into your router and turn on DMZ( you have to set it to your Xbox settings) and that should do it.... i had the same problem and pain over 100$ for a computer guy to try and fix it... then i nded up fixin it mysel.... the only other thing it could be is that your router is to far away and doesnt have enogh power....
Hope this helps :)
Feb 14, 2009 | Microsoft Xbox 360 Console
Doesnt connect
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support. :-)
Jun 08, 2008 | Linksys WRT300N Wireless Router
Dns error 80710102
when it is a DNS error, this means that it is an internet problem on your internet service provider's end.
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
Problem connecting
I think the easiest thing would be to reset the router to default. There should be a reset hole on the back of router. This sets SSID to router manufacture name and ID and Password are set to "admin". Then it should just automaticly connect. You can then change SSID, ID and Passwoord. Connect to the internet with a browser and then reconnect the cables from modem to router to computer. Hopefully this will help or solve. Thanks..!!
Feb 16, 2008 | 3Com Office Connect DSL Router with Free...
Problem in wireless connection.
ok First Didnt say what operating systems you were running 2Have you updated from windows SP2 let me Know ttech
Aug 01, 2007 | HP Photosmart C6100 All-In-One Printer
Nintendo Wii Console Logo
48 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
