Question about Schumacher & Fast Charge Starter Charger
How do you read the gauge. Is 100 fully charged or is it empty?
    Guru:
  • 509 Answers
The gauge reads the amps that the charger is putting out. So 100 would mean the battery is dead and 0 means it's fully charged.
Posted on Dec 28, 2010
How can i tell if its my fuel sensor that is bad or if its something completely different on my 2005 Nissan pathfinder?
First you need to read the codes at a garage with a code reader. They will normally do this free of charge in the hopes of getting the work. The gas light is on because the gauge is reading empty. you have to find out why the gauge is showing empty. Check the manual for the fuse that covers the fuel gauge. It may also be the float level sensor inside the gas tank.
Feb 18, 2018 | Nissan Cars & Trucks
1978 chev k10 alternator output 14.4 on bench, reads 9 amps on truck gauge 12.2 on ampmeter at battery with truck running why
amps reading on the truck amp meter is the current that is being generated to run everything as well as charge a battery that will be at best around 80% charged.bench testing an alternator gives these readings as the regulator is feeding into fully charged batteries with no draw on the system. When batteries are 100% charged the charge rate will be as low as 2 amps but in a car where there is a current draw for the ECM , ignition , fuel pump and what ever the alternator feeds these first before it charges a battery. You used a amp meter to get a voltage reading which is reading the voltage drop across the current draw. If you had used a voltmeter (multimeter) then you would see a voltage increase with the rpm increase. The
Aug 14, 2014 | Cars & Trucks
GAS GAUGE STUCK ON FULL
well its not connected>? or you forgot to ground the ground wire?
if you had a DMM meter , this would be easy,
you can measure the sensor ohms, at any time with tank in car.
and id have never put back any tank with out checking it first.
not me, pulling tanks is no fun.
and empty tank the gauge sender is at max ohms, (lever down)
so is about 100 ohms and 10 ohms full (ball park) RTM
read the FSM read alldata.com
heck the FSM has a flow chart for these tests. amazing huh?
i dont use it, i use my meter and ohms law.
ill now look online at alldata.
the only think complex is which of 2 systems it is,
in the late 90s most cars changed. to indirect way.
ok , i looked, your car is direct way, (cave man)
its just 2 parts, a gauge and a sender. (sure wires)
the sender is grounded at G751
if the dash temp guage works , then the fuse is not blown , fuse 1.
the tests are cave man simple , all FSM show this.
1: unplug the Yellow/Blue sender wire, at any point
from front (gauge) to sender, any place, there are many.(4 junctions)
now, on the upstream side, key on, and ground this pin for 1min
max, if guage moves pull the ground. (i use $#194 lamp for tests )
i connect my lamp to ground and the other side to the guage,wire.
then key on and see guage move. bingo gauge is 100% good.
cave man easy. (
now the sender.
i measure the ohm.
DMM on 200 ohm scale if manual meter.
i connect black meter to body ground (shiny steel not plastic)
i connect red lead to down stream wire above..Yellow/Blue
it must read 100 ohms empty
not 0 ohms.
not infinity.
if read infinity? the wire is cut, or gound it open or the sender is bad.
if reads 0, the wire is grounded to the body or the the sender is bad (shorted)
do not take my facts on ohms as verbatim,
read the FSM and get the facts.
but i think your tank sender wire is shorted to ground.
some gauges work backwards, and my poor online version
dont cover this. well.
unplug the sensor does guage go full or empty?
most go empty, but not all.
use the lamp to test the gage, get to swing both ways
with lamp to ground and with lamp and wire disconnected.
cheers.
Dec 02, 2013 | 1997 Acura CL
2003 honda crv fuel guage below empty when actually full
The float is sinking. This could be from alcohol used in gasoline.
Apr 20, 2013 | 2003 Honda CR-V
Fuel gauge reads past full all the time
when the tank is full the resistance is low so the power through the gage make is read full
as the tank empties , the resistance increases so the less current means the gauge reads less until empty there is little or no power , the gauge reads empty
simple check , turn the ignition off, no power , no gauge reading
Sep 09, 2017 | Chevrolet S 10 Cars & Trucks
Check gages on jeep grand cherokee
If your "Check Gauges" light is on, the light means pretty much whay it says...CHECK GAUGES! One or more of your gauges is/are reading outside of normal operating range. You could be having an overheating problem (Temperature gauge near or in the red) You could be having a charging system problem (Battery or Amp gauge reading in the "discharge" or "low voltage" area.) You could be nearly out of fuel (Fuel gauge reading near empty) Your oil pressure could be low (OIl Pressure gauge reading very low)....You have to look at your gauges to find out what is going on that is not normal.
Jan 29, 2011 | 2003 Jeep Grand Cherokee
What is proper way to read the meter on the front of the battery charger
The numbers on the gauge is the amount of power the charger is putting out in amps. The lower the gauge reads the more the battery is charged. 0 (zero) means the battery is fully charged.
Nov 19, 2010 | Schumacher & Fast Charge Starter Charger
Check gages light came on. the gas gage read 20 mi to empty. turned it off then on again and read 107 mi to empty. the engine soon died in the middle of traffic. Is it the battery???
The battery is one possible problem. However, the alternator charges the battery, and if that goes bad, the check gauges light will go on, in particular, the charge light will go on (red in color).
This is actually a very common problem. If the alternator is bad, it can cause the car to lose voltage over time, 30 to 40 minutes after the light goes on, the car will die if operated for that period of time with a fully charged battery, even.
Aug 17, 2010 | 1999 Jeep Grand Cherokee
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Schumacher & Fast Charge Starter Charger  Logo
680 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
