Question about GE Spacemaker JVM1640SJ Microwave Oven
After i press start, the microwave resets itself after running for 2 seconds. any ideas what is the problem?
MicrowaveSvc
  • 9047 Answers
SOURCE: Jenn-Air Microwave M169B 11 years old.
You should be able to get a replacement keypad, and that's not a hard job for a DIYer.
If you're interested, post your correct brand and model and I'll give you a more specific suggestion.
(Your post subject says Jenn-Air M169B put it's posted under Sharp R-316FS so I'm not sure which you have).
If it's a Jenn-Air, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
You can usually find Sharp exploded views by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from there or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 21, 2008
Master_Tech
  • 770 Answers
SOURCE: microwave turns itself off after a couple of seconds
try to press in on the door after you strat it or down on the door after you start it your interlock switches my be going out
Posted on Jan 24, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: fan in the GE microwave (over range top)
Can you reply back with your full model number?
I'm suspecting you may have a failing keypad (membrane switch) on the control panel assembly.
We repair these for customers nationwide by mail for $39.95 plus part cost.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you want to do it yourself, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Posted on Mar 30, 2008
SOURCE: Neff 5474.0/gb. When microwave time
After a bit of digging, it appears to be an issue with the door not being closed correctly (or at least the it thinks is isn't.
Ref:http://www.sampfordixl.com.au/gaggenau/upload/BM221130_instr.pdf
I know its a different model but the functionality is identical...
Posted on Jun 12, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Ge microwave oven - JVM1653SH shuts off
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may send you a replacement magnetron. GE Customer Service is here.
Posted on Nov 21, 2008
I have a microwave model # R-308NW. When I press
if when it shuts off clock resets to first plugged in state, sounds as if control panel is being reset by something (failure of part, or power surge) if clock is still ok and maintains correct time , I'll bet if you notice the cooliing fan is not running correctly (by sound it makes) in those two seconds, this will over heat magnetron and shut off on thermal hi temp (safety) if so fan will need to be serviced by a professional
Sep 10, 2014 | Microwave Ovens
The timer doesn't work right.
Are you programming it for 2:00 or just pressing 2, then Start?
Try resetting it by unplugging it for a couple of minutes, plugging it back in, then setting the clock and trying again.
Jan 08, 2013 | Maytag MMV5207A Microwave Oven
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My child locked the microwave pad. How do I unlock it?
The operation manual is available for free download from Samsung at this site: http://downloadcenter.samsung.com/content/UM/200305/20030529145700437_MW5592.pdf
The answer to how to lock and unlock is on page 15 of the manual. It's instructions are: 1. Press the '0' button, the display will show: "PRESS 1- DEMO 2-CHILD LOCK"
2. Press the "2" button, the display will show: "PRESS START"
3. Press the start button and the display will show "LOCK" then returns to the time of day.
At this point the microwave can't be used. To unlock, just repeat steps 1-3.
Hope this helps
Jun 18, 2011 | Samsung MW5592W Microwave Oven
Microwave starts and runs 2 seconds and stops. Display is jibberish. After resetting date and time, it will again run 2 seconds and then shuts down again.
See this FixYa solution. even if your model number is different.
Oct 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MY GE SPACEMAKER MICROWAVE CUT OF AFTER ABOUT 5 TO 10 SECONDS
might be a short in the system to cook the food or a short in the board for it if there is i would recommend in getting rid of the microwave or getting it fixed otherwise its a big fire hazard for ya
Hope this helped ya
Cheers
Johnthetr870
May 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns itself off after a couple of seconds
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jan 22, 2008 | Thermador MBYB Microwave Oven
Jan 17, 2008 | Sharp R-316FS Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
