Question about Dell 1600n All-In-One Laser Printer
Dell 1600n Cartridge Sensors messed up
I just got a paper jam and had to remove the toner cartridge. When I put it back in I got the message Jam [1] or No Cartridge. I took the cartridge back out and looked inside to see if any other papers were jammed, and I noticed that there are four prongs on the inside that look like they are the connection to the toner cartridge computer chip. The one on the left side is not "in place" like the other three. Is there a way I can fix this, or is this a technician only fixable area? Please help and thanks :)
  • 2 more comments
  • JoePODatdell Jun 14, 2008
    Same problem... Dell is blaming it on the cartridge I replaced it, NOT a Dell and their tech support is still blaming it on cartridge but that makes NO sense to me since both of these cartridges get the same error. That makes no sense but, tech support seems like too many add-on mechanics where I've spent tons of money and not fixed the problem.
    I've torn the machine apart and, no jams that I can see so...
    "Paper jam or missing cartridge"... new cartridge and I get the same error, tore the machine and checked all paper paths... not good enough for Dell's tech support... Dell's TS won't even consider their MACHINE might be signifying a jam because of faulty sensors but, nothing else makes sense to me. Their TS SOP's force them to get the consumers to buy 'Dell' and they won't even bring any intelligence to the problem without it!
    I'm at a loss, I can pay to go to a competent printer technician (I don't trust Dell technical skill because of poor support judgement and poor judgement translates into lots of $$$ for us consumers) so, any suggestions?
    Joe
  • dbultema Jun 21, 2008
    Same problem here. It goes away for a bit if I turn off and unplug the printer for a while, but later comes back. I agree it sounds like some sort of sensor issue. This issue is driving me crazy!
  • sam2010 Feb 11, 2009
    I have the same problem i would like to try solution #2 but couldnt locate the "little spring sited in left side of feed sensorĀ“s actuator" pl. help
  • sam2010 May 11, 2010
    i am trying to locate the little spring on the left side pl. help
I opened mine up and that was not the problem what I did to fix is took a clean piece of paper towell wrapped it around a paper clip and cleaned the sensor where the paddle drops down. It may be that the eyes were dirty and could not see.
Posted on Jul 07, 2008
The cause of this problem is a little spring sited in left side of feed sensor´s actuator and keep it on it´s right position: sensor actuated(off);if this little spring is out of position,feed sensor´s actuator go out of position and machine´s main board detects high(on) signal showing a paper jam message.
Posted on Jul 05, 2008
Dell 1720 laser printer shows paper jam after clearing jam and turning off and back on.
some paper piece may be left in the printer.
Please check where was the leading edge of the paper when it was jammed. some sensors may have got stuck while removing paper. open the toner door remove the toner cartridge, just see all the sensor flags with fingers, refix toner and power on and try printing
Dec 01, 2009 | Dell 1720dn Laser Printer
1600n grinding and jamming
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Jun 11, 2009 | Dell 1600n All-In-One Laser Printer
Paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Grey arm is in place. cannot find any paper anywher that is a jam
this can happen if any of the contact points on the cartridge are even remotely scratched or if the cartridge is "low" even if it doesnt say its low
Please Rate Me
May 28, 2009 | Dell 1600n All-In-One Laser Printer
Paper Jam
try these steps
alternative :
Feb 14, 2009 | Dell 810 All-In-One InkJet Printer
Paper jam 2 - checked every area - cut equipment off and back on - still paper jam 2 - need service person asap.
there are 4 or 5 sensors through paper road:
1)paper input sensor near input roller
2)margin sensor between input roller and cartridge unit
3)transfer bell sensor between cartridge and fuser unit
4)fusing sensor before fusing
5)out put tray sensor
check all sensors if you can find out and check any paper jam there and check sensor stander at normal position, also check each sensor click ok(the micro switch ok) .
there is any sensor out of work should be showing paper jam.
Jan 23, 2009 | Dell 1600n All-In-One Laser Printer
Paper jam, Is this the fuser?
I have had the same problem. Changing the fuser is easy (about $85, and must be ordered through Dell) remove the 4 screws from the back, and you'll see the fuser. 2 screws, and 2 wires, and it slides right out.
Jul 16, 2008 | Dell 1600n All-In-One Laser Printer
Toner dumps all over the inside, paper coated all black and jams behind fuser
We to have this issue with one of our 1600's. I tried to resolve this by replacing the fuser with a new one. Haven't got back around to trying to resolve this as it such a mess to get started. Someone resolve this issue yet?
Jun 01, 2008 | Dell 1600n All-In-One Laser Printer
Paper Jam error message
try this
alternative :
Apr 02, 2008 | Dell 942 All-In-One InkJet Printer
I have dell 1600 multifunctional jam 1/no cartridge
I have been having the same problem. I almost gave up on this printer. After careful analysis I noticed that if I pulled up on the cartridge while it was inserted and held it up (I took the door off and depressed the door closed button w/ a screwdriver) the printer would work fine.
I shimmed the front of the cartridge w/ a piece of rubber or folded up paper. There appears to be something in the back that doesn't make full contact if you do not do this. Now it works fine.
I haven't had any feed problems, but I kept my shim to the front right and made sure it doesn't go too deep.
Dec 17, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
330 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
