Question about Roper REX4634KQ Electric Dryer
My dryer is not listed, howver the model is a REX6634PQ0 Type D433-ELE-2406028-FM-54 the problem is that it doesn't heat, and the timer doesn't move.
  • Roper Master
  • 7,482 Answers
Replace the timer, it is probably faulty...also follow the intructions below and that should sove your heat problem.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 10, 2010
  • mariangs Nov 02, 2010
    how do I clean the lint of the same dryer?
My whirlpool dryer model ler3624jq1 type d433-ele-2406028-fm54 isnt drying my clothes completely
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Jun 17, 2012 | Dryers
Two problems with Whirlpool Dryer
I would suspect the heating element. I bet you are asking why this clown is saying that when you already told him that on high heat it worked fine. SIMPLE! Your heating element is made up of five coils. For low heat your dryer uses two heating elements and for high all five. So if one or two of the heating elements are open and they happen to be the low temp dry setting ones, that would explain it. That model doesn't have the dryness sensor on it (according to my documentation) so the heating element is the most likely cause.
Hope this helps!
ImJustAvg aka Hal
Dec 30, 2011 | Whirlpool Dryers
I have a whirlpool Dryer type: D433-ELE-2406028-FM54, Model: LER463JQO. It takes atleast 2 cycles to dry the whole load completely, and I'm wondering what I can do to fix this problem?
You may have a clogged vent pipe. I would take it apart and clean it all out.If that doesn't help then you may have other problems.Could be thermostat or one bad element. Hope this helped.
May 05, 2011 | Kenmore 600 6965 Electric Dryer
Trying to find a heating element for one of these Whirlpool dryers. Mod# TEDX640PQ0 S/N MR3518675 Type D433 ELE 2406028-sm54
Try a retailer that sells and services them they usually can order those for you thats a popular brand so it should not be too hard as long as its not a real old model.
Nov 12, 2010 | Dryers
Dryer will not start whirlpool model #LER4634EQ2 SERIAL #MK0296464 TYPE#D433-ELE-2406028-FM54
It might be the fuse.3727d80.jpg Be sure you do a bit of cleaning before you replace the fuse or it might just blow again.a611954.jpgca0922b.jpg Look for lint. I looked up your model. I once did a write up about what goes wrong, how to get into the machine, a training manual and videos. HERE
Bonus stuff
Helpful? Rate please.
Sep 19, 2010 | Whirlpool Dryers
MOD: REX4635EW2 SER: MJ0922226 Type: D433-ELE-2406028-FM54 Won't turn on just buzzes when hit the start button. Have already checked plug in and braker box?
Remove the back panel from the control panel to access the start switch. If there are 4 wires on the start switch,replace the start switch.
Aug 18, 2009 | Roper Dryers
Kenmore dryer hums/heats up, but drum does not spin!
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Yank out the tub. Clean the junk out (send me the coinery) oil the wheels and Idler with temp resistant zoomoil from ace hardware. Use this guide to replace dat belt Kimosabe:
BELT CONFIG 101
Apr 08, 2009 | Dryers
Wont dry
WHAT BRAND IS ( LG WP KENMOOR OR MAY TAG) I NEED TO KNOW THANKS
Apr 04, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
108 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
