Question about Samsung RS2530BSH (25 cu ft) Side by Side Refrigerator
The fan motor started making a sqealing sound about two weeks ago. Then noticed a burning smell this morning. Checked it again this afternoon and the plastic divider between the fridge and freezer is so hot you almost burn yourself when touching it. What could be the problem?
    President:
  • Samsung Master
  • 2,651 Answers
You indeed do have a bad condenso rfan motor.. its the fan by the compressor behind the unit,,i couldnt find your model number on my part look up, but you can call samsung direct( cust service line) and with the entire model and serial number they will be able to determine the correct part number, you want entire condensor fan assy with housing and fan blade... it will come complte, you will simply unplug and snap in the new unit housing and all.. inn meantime i would pull unit away form wall and with a desk top fan orwindow fan blow it on te compressor to keep it cool you dont want to overheat the compressor. the youll have major problems
Posted on Oct 09, 2010
Car heater blowing cold air and rubber burnning
If your heater is spraying a light mist through your vents it could be your heater coil. Mine did the same thing, smell rubber burning, then started a light mist through the vents. If you don't get that checked out, it could mess up your water pump and possibly your engine
Jun 22, 2014 | 2000 Chevrolet Cavalier
Renault Megane Dynamique 1.6 2004 - Heater fan stopped working - wet front footwells
Im almost sure that your problem is a broken or leaking heater core and needs to be replaced cose 1 your coolant level allways will be low due to the leak and 2 it could damage your blower fan motor. if in winter time you need the heat fixit... If not you could cancel the 2 waters hoses going to the heater core. hope this helps.
Jan 28, 2014 | Cars & Trucks
Yesterday I was leaving work and my van started running rough and it smells like gas. It was not shutting off just runs and idols rough. It was fine this morning when I took the kids to school then started...
Sounds like it could be a gasket leak, or a fuel line leak. Here's why; when the motor gets hot things expand/swell, with it acting up in the afternoon only i think it could be due to more heat causing expansion as compared to when it is cold. I would check for leaks first due to such an intense aroma of gas. Then i would look for gasket leaks around the throttle body which can be checked by spraying starting fluid around the throttle bottle and taking notice if there is any performance/idle change. IF so there is a leak, try to pin point it if possible. Most likely though i would say a fuel leak of some sort so look for a puddle of gas or wetness in the engine compartment around the intake manifold.
Oct 12, 2013 | 1997 Chrysler Town & Country
Noise and burning smell from heater
Yeah.
Pine needles get into the heater box and clog the heater fan motor's "fan".
You also may have rodents in there,making nests.
The wife was smart to turn off the heater fan B-4 the fuse blew.
Feb 21, 2013 | 2006 Toyota 4Runner
1992 GMC Sonoma - 4.3l cannot start after stall and knocking.
Sounds like an engine sensor, EGR valve or O2 sensor has failed. First thing to do is to look at the engine trouble codes to pin down the failure. You can usually borrow an OBD1 code checker from your local parts store.
Mar 11, 2017 | 1992 GMC Sonoma
I have a rheem furnace. A week or so ago, we had a burning smell, and the furnace shut down while I was gone. When I came back, it did start again, but the smell was still there. I called a guy who came...
Your control board may have a problem. When the burner fires up, after a time delay of about 45 seconds, you need to use a voltmeter and see if the terminal marked H for heat has 120 volts coming off it. This voltage will be the power to spin the blower. If ther is 120 vac at terminal H then the blower motor or cap. is no good. If there is no 120 vac then you may have a bad control board.
Jan 03, 2009 | Heating & Cooling
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Heater problem model PHK 080-1
THE BURNING SMELL IS NORMAL. BEFORE HEATING SEASON OPEN ALL DOORS AND TURN THE HEAT UP AND LET RUN TILL ALL DUST IS BURNT OFF. IF BLOWER IS NOT COMMING ON NOW. THERE ARE 2 TIME DELAY RELAYS, AND ANOTHER RELAY FOR "FAN ONLY OPERATION". ALWAYS MAKE SURE THEY ARE NOT THE PROBLEM BEFORE REPLACING AN EXPENSIVE MOTOR.
Feb 07, 2007 | Goodman PHKJ060-1 Air Conditioner
Samsung RS2530BSH (25 cu ft) Side by Side Refrigerator Logo
330 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
