Question about Sony Xplod XM-554ZR Car Audio Amplifier
Power protector light on sony xplode 1000 watt amp
A couple days ago i was driving down the road and my ground wire came out of my amp. when i got home, i put it back in and changed the ground to a spot underneath my back seat. (1997 chevy cavalier). Then i started my car and the green power protector light comes on. I moved the ground wire back to the place i had it grounded to before and the power protector light still comes on.
  • 1 more comment
  • rkbizzle123 Jun 01, 2008
    so what do i do to make the power indicator light turn off?
  • cutepoison Mar 22, 2009
    my grounding came off and i also changed the grounding spot, whilst changing it a few of my wires came off so i put them. everytime i turn my radio up, the red light flashes for the protection. iv been able to turn it up before, so how do i turn this off?
  • Anonymous May 26, 2009
    after running two 1200watt 12" pioneer subs the subs poped a cupple of times and than the protection light came on
A green light is the power indicator, a red light is when the protector is in affect
Posted on Jun 01, 2008
I bought a used sony xplode 1000w amp from a friend. i hooked it up to my two 12" kicker procomps. i have a 99 nissan frintier. i have my ground under my center console with all my other ground wires. a few days ago i noticed that the green power protecter light turned red after my power wire fuse blew. i replaced it and checked alll of my other fuses and rewired and checked all of my conections but my subs will not play at all. the amp has power but is not pushing my subs. my subs are rated 800 watts a piece. Y will they not play?
Posted on Mar 06, 2010
  • 3 Answers
Certain spots in the car is grounded different i know the new spot u moved it to is probably noticeable but it always easy to find a ground u just need to have lenght in the wire
Posted on Apr 17, 2009
Radio quit working
Sounds like someone shorted the wires...you need to look into the entire butcher job and see what wires were touched. Disconnect everything the butcher did and then see if your battery is still drainning power.
Dec 03, 2013 | 2006 Chevrolet Malibu
MX5 battery light on whilst driving
howdie sounds like their could be ground problem but put the alt, under load and see what it puts out,if the battery was changed look for clamps are not loose check your ground to motor wire for corrosion
Jul 25, 2012 | Cars & Trucks
Why do the fuses on my scion xb keep blowing?
Did you check to make sure the fuses are the right rating to begin with. Fuses are rated by amperage and disconnect the circuit or "blow" if there if the circuit is shorted out (+ touches - or vice versa) or a device or circuit draws more amperage than the fuse is rated. Did you buy the vehicle new? If not then there may have been modifications. Does is have the stock radio? Does it have an amp or subwoofer? Driving lights? There is also a fuse block with relays and fusable links under the hood. Refer to the owners manual and verifiy all the components in both fuse blocks are of the correct type and rating. Physically remove and inspect every related fuse and make sure no one has "jumped" a fuse by wrapping it in foil or ataching a solid wire across the connection. If all that works out ok, have the voltage reguator checked as it is regulates a constact rate of power to the car. If is is allowing momentary surges, it is possible that it could exceed the cirucit ratings especiallly on the 10 and 15 amp circuits that most of your accessorys and lighting use; Good Luck.
Feb 10, 2012 | 2005 Scion xB
I have a 1990 ck 1500. a couple of weeks ago I was headed out the driveway, it was a rainy day, I hit my headlights and my radio went out.I immediatly turned off my lights and my clock was re-set at...
On the components, you might try a separate ground. See if that helps? Check the battery negative connections. I've seen this even on newer vehicle where instrument cluster or whatever would dim a little when you turn on headlamps. I think it's a ground issue? Just my opinion.
On any component that doesn't work, check voltage and ground, you could try a redundant ground.
Mar 13, 2017 | Cars & Trucks
I have a 2004 Chevy Cavalier. A couple of months ago, just after starting the car one day, the 'check engine' and 'trac off' lights both came on. I immediately shut off the car, waited approximately 5...
Many cars have the cooling fan on a thermostat or time delay, to allow it to run for a short period of time after the engine turns off, to cool the engine off. You may have just never noticed it before. So I wouldn't worry about that.
Your real problem is the blowing fuses, apparently you have a short somewhere in your wiring. Putting in bigger and bigger fuses is a great way to set fire to your wiring harness. It's possible that the wire is pinched or chafed somewhere, and perhaps when you hit a bump just right, it touches and shorts.
You may have to take this to the Chevy dealer or a GOOD independent shop to have them chase it down. Unless someone out there knows exactly what this is, it could be a tough one to find.
Apr 26, 2011 | Chevrolet Cavalier Cars & Trucks
96 jeep cherokee. Started acting up a month or so ago when I was driving in the rain and started driving over a rough road. Problem escalated to point the jeep wouldn't start. I noticed the ground that...
With any loose wire situation, I'd have as much luck telling you which wire to look at as if you would to try and guess which persons shoe was untied in a dark movie theater. There are just too many of them, all of which are important.
One thing you can do to eliminate ground problems without actually finding a problem is to run an independent ground wire from the battery to the right fender, back to the firewall, around to the left fender, then to the front cross bar above the radiator. Use a minimum of 10 gauge wire for this, and do not use separate pieces. Strip away insulation at attachment points and make a loop, attaching with a short self tapping screw and washer. I also discard the factory negative battery cable and use a very heavy wire (I use welding cable) . Same applies to positive cable. Anywhere there is a factory ground lead I connect the new ground wire, cleaning the screw holes and the new ones I added with rough sandpaper, making sure there is no paint on the connection. I also run a separate feeder ground from the continuous ground, through the firewall to the cross brace below the dashboard. This may appear to be "overkill" but I never have to wonder if there is a sufficient ground anywhere. Use a squirt of undercoating on each new ground for rust protection.
Back to your problem...The oldest test is likely going to be the best one for you...Try wiggling the harness at different places and see if the engine stalls or stumbles.Since the problem began after impact, check that the impact sensor and auto shutdown relay are working, and that the wiring is not pinched or damaged. The impact sensor can trigger the airbag so be careful when working with it. Computer problems are not as common as you would think...You see many posts here dealing with them but no one posts about what they have that's working there are many more working perfectly than not...Could it be a computer problem ? Yes. Do I think it is? I doubt it. When running the grounding wire, there are usually at least two ground wires that come from the computer harness. make sure they are properly grounded as well.
As with any no-start problem, do the majority of your testing when it's not starting...when it's working, whatever is not working is not going to show up..I once spent two weeks carrying around test equipment to check an electrical problem on my own vehicle. Problem would always show up two or more miles from my shop and would disappear as soon as I got within a hundred yards of the shop or home. If I hadn't tested it where it died, I would never have found it till it had gotten so bad that I would have gotten stranded. Be safe and don't get out on a freeway, but do carry a volt/ohm meter with you to do quick side of the road or parking lot testing.Try to first isolate what is going down (spark or fuel), then get more specific with tests. Parts you have changed are suspect 'till they have been tested...Quality of parts today is horrible and cannot be depended upon .
It may take some time, but you will find it!
Good luck
Jul 28, 2009 | 1996 Jeep Cherokee
Shuts off will driving, especially if I hit a bumpy road.
check the wires to the fuel pump if they have rubbed against something and the insulation wore through hitting bumps or rain could cause it to short and kick the relay and resets again and will start
Jul 06, 2009 | 1996 Jeep Grand Cherokee
1989 f250 lost all power driving down the road.
Ignition coil going bad it seems. They die out slowly & not at once
May 24, 2009 | 1989 Ford F 250
Sony Xplod XM-554ZR Car Audio Amplifier Logo
2,362 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
