Question about Acer Aspire One AOA110-1113 Netbook
Just done an bios upgrade everything went fine but guess what yes it went wrong the computer shut down yellow light in the upper right hand corner stayed on charging light was also on nothing on screen waited for a while then pulled out the power cord nothing then took the battery out plugged it back in and to my supprise nothing no charging no power no start up !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! now when i put the power lead in the yellow light flicks for a second but nothing please could someone out there help me have i fryed the motherboard or what is the problem it just dead fixable or binable
    Habit-Forming:
    New Friend:
  • Acer Expert
  • 195 Answers
Take off : power cable , battery wait 5 min
open the case take off the c-mos battery , wait 5 min
mout everything , start the machine again , whit all connections , so you did a reset from your bios
Posted on Apr 18, 2017
  • 83 Answers
SOURCE: Acer 3500 series wont turn on.
yes, it sounds like the mother board battery has failed,,,either remove your keyboard and it is a round battery in a plastic holder,,,remove carefully u can buy it at walmart for less than 5 bux replace, re-install keyboad and turn on...good luck
Posted on Jul 09, 2007
  • 6 Answers
SOURCE: Acer Aspire won't start
make sure the plug is completely secure into the back of the laptop.. i also have an acer aspire..
maybe someone spilled their drink on it...
..idk..
Posted on Jul 30, 2008
SOURCE: My Acer Aspire one won't turn on.
I also have this problem with my Acer netbook.  I have only had it for 4 months and am in Turkey on an extended break at the moment.  I have taken the netbook to a dealer here and have been told the problem is the motherboard, verified by Acer themselves.  I am not happy with this as the netbook was not cheap and there appears to be a few Acer models with the same problem
Posted on Apr 10, 2009
SOURCE: my acer 3004wlci wont power up. when i put the
I had the same problem. I removed the battery and just used the AC Power Adaptor. The machine powered up and ran fine. I replaced the battery and have had no problems since (2 years ago now)
Posted on Mar 30, 2010
SOURCE: bios password for acer travelmate 2410
i have had just the same problem, i took my laptop apart removed the cmos battery its just to the side of the trackpack on top of the motherboard, but this did not work, HERE is the solution with out stripping the all the laptop make sure the battery is out and no power to the laptop all you need to do is take the plastic part with the power button on off and underneath you will see a small switch called SW1 move the number one switch to on then power up the laptop press F2 and there you go your in the bios, save all settings turn off put the switch back to where it was put you plastic facia back on replace the battery power up now press F2 and do what you want all is good
Posted on Aug 09, 2010
My iphone has my last name wrong on caller ID
Your iPhone uses the name that is listed in your address book for called ID. On your iPhone, go to Contacts, click on the name of the contact you wish to edit, hit Edit in the upper right-hand corner, and then change the last name accordingly. Once you are done, hit Done on the upper right-hand corner again, and now the correct name will show on caller ID.
Jan 28, 2011 | Apple iPhone 3G
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
My amazon kindle screen is frozen on the right hand upper corner. The rest of the screen is still fine and works but that corner is frozen.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Jan 02, 2011 | Amazon Kindle 2
Hi - my computer automatically shut down while I was online and kept telling me that the hard drive was at capacity.... - it wouldn't even let me control the volume without it saying something was wrong. ...
The hard drive has picked up a virus and corrupted window or the hard drive is defective, if you have the proper recovery disc give it a try, if it works you will have a fresh install of windows and you will know the hard drive is good.
Dec 20, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have an Intel D845HV motherboard running with a
In short, yes you can upgrade to a P4 cpu but from the compatibility chart at Intel support, it looks like the upper limit for this older board is the P4 2.6GHz.
Note: Even at that, running the P4 2.6 would require a BIOS upgrade to P12 or greater.
Luckily, the following link has the information you seek: (for BIOS info, click the "BIOS Version" link in the upper right corner of the compatibility table provided)
Intel D845HV CPU Compatibility
I hope this info is helpful!
Mar 08, 2010 | Intel D845HV (735858149143) Motherboard
My universal serial bus is not function
ok
Check if is not disable in the bios........
Tips to enter the Bios
1.Turn on or restart the computer. Press f10 while the F10 = ROM-Based Setup message is displayed in the lower-left corner of the screen.
Jan 15, 2010 | HP Compaq nx6110 PC Laptop
Blue dots center and yellow stain right hand corner on 60'' sonytv
Yes, I do. It needs a new light engine. Very costly repair. However, Sony has extended the warranty on many of these LED projector sets. You need to call a local Sony authorized service center and see if your model is covered. Otherwise this repair could run over a thousand bucks.
Jun 14, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
Acer Aspire One AOA110-1113 Netbook Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
