Question about Toshiba 62HMX84 62" Rear Projection HDTV
Hello, I installed a replacement lamp, thinking it was a lamp problem. Red/green lights blink and turn off after a few seconds. This process repeats and the image never comes on. Please let me know th ebest way to troubleshoot and know the issue.
Http://www.tristatemodule.com/default.aspx
The bulb gets its spark from a unit called: Lamp Engine. If the lamp engine is bad, you get no spark, maybe the ballast is bad. This place above can re-build your lamp engine. A new one is $500+. Seen some for $600. Service calls are 150-200. You can take out the lamp engine if you've got some tools and the will. Send it to them for an examination and rebuild. They told me if I could switch channels while my set was trying to come on, and I got audio from the other channels, it most likely is the lamp engine.
Give it some thought. Toshiba didn't tell me about that, Geek Squad did. Toshiba doesn't seem to give much of a darn about you once you spend your money for the set. Good luck. RW
Posted on Nov 23, 2010
I'm assuming that it is an error code. The red
colour wheel issues and defective lamp replacing lamp and light engine color wheel cos its worn out
Jul 07, 2013 | Televison & Video
Panasonic PT-52LCX66 blinks green then red lamp light comes on
Replace the lamp cartridge. You can get the replacement DLP lamp from www.tvrepairworld.com and the lamps come with installation instructions
Oct 27, 2012 | Panasonic PT-52LCX66 Projection Television
Hello, i have a problem with my TV. When we turn on TV, after few seconds the screen turns off, and green power light starts to blink, after that the picture returns back on. And in few seconds this...
The problem you are having is likely the lamp is bad and needs replaced this happens when the lamp gets weak replace lamp should fix your problem part # is xl2400
May 24, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My KDF-42WE655 will not turn on . The green start up light comes on and I can barely see the tv come on . After a few seconds the red light starts blinking and does not stop. The screen never comes on ....
Hello! When was the last time you replace lamp in your TV? If long time ago (2+ years) - replace the lamp. If red light blinks in sequence (example 4 flashes, pause, 4 flushes, pause and so on) - then I need to know how many flushes between pauses. It is an error code. If it blinks just constantly - it is a bad lamp. Regards. Russ.
Apr 18, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony model#kdf50e2000.turned it on a few days ag0 heard a few clicks, green light come on a few times then it gives me three red blinks stops then three red blinks again and again.no sound no picture.i...
Your lamp door switch or lamp switch (there are 2) may not be fully engaged or one may have failed. Try seating the lamp again, you may not have it fully installed.
Mar 17, 2010 | Televison & Video
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony kdf50e 2000- green power light turns red what to do
Does red light blink? if yes, please count blinks as there would be pause of 3 seconds between blinks and let me know to help you out.
Feb 12, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
166 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
