Question about HP DeskJet F380 All-In-One Printer
I installed new ink but still wont print due to low ink
Hi, i am having the same problem and have had endless problems with this printer ! what a load of junk ! my best advice is to buy a new one as that is want i am going to do but will certainly not be from Hp !
Posted on Oct 21, 2010
My canon printer mp 630 takes two black ink cartridges. one regular size and one larger The smaller one is very low.on ink. Is that the reason the printed picture is of poor quality having a lot of...
It need not be the case due to a low ink level in the smaller cartridge but if there is a problem with the printing head this can be a suspect. So try and use a good head cleaning then reset the printer driver software after un-installing and reinstalling before the printer is connected once again.
If this wont solve the ink cartridge must be changed to have a last try before the head is doubted. .
Mar 21, 2011 | Canon Office Equipment & Supplies
Wont print, says ink is low.. ...but will print
problem could be not compatible with the windows program
most windows vista will not except any printer made before windows vista.
Apr 08, 2010 | Dell 966 All-In-One InkJet Printer
Hi I've just replaced the ink cartridges thinking that the print problems were due to low ink - I've tried calibrating and cleaning the print heads but I'm only getting fain blue and grey tones printing...
These printer has a defect ... is the print head.. just call there support number they will replace the head.. I had to do it twice already. New problems is gone for a little while.. It wont hurt to try...
Oct 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Black ink cartridge wont print, have installed a new ink refill still no joy. Will print in all other colours.
Well if you already installed a new black ink cartridge and still wont print, then try cleaning your printer head. It can be that the some ink was hardened and got stuck preventing you to print a black color.
Jul 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Claims new ink cartridge is low...
Hello, at this point I would suggest COMPLETELY uninstall your photo printer, reboot your system and reinstall. Hopefully this helps.
I will tell you though, usually if after running cleaning utilities, the picture still has lines and spaces, could be due to print heads drying up and unable to output the proper amount of ink. This happens alot when people are not using their printer often enough to keep the ink flowing properly.
Recently I had to replace a printer that I had not printed on in like 3 months, the print heads dried up/ clogged up. And the new ink I had just purchased was a waste of money. Had to replace entire printer.
Feb 04, 2009 | Epson PictureMate Photo Printer
Ink was low I put a new cartridge in still says low wont print.
Hi
try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Deteriorating Print Quality
This is Maltesecross. Turns out that the faintness of my printed pages was in fact due to a low ink cartridge, even though some pages printed out fine and others half-good. Eventually, all pages turned faint, and upon re-installing the driver, I got a low-ink warning (the first one ever). Putting in a new ink cartridge solved the problem for me.
Oct 21, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
