Question about LG LRBN20510WW Bottom Freezer Refrigerator
LG bottome freezer/refrigerator
My freezer ending in 20512WW, bottom freezer ice maker, is not in use and I would like to have the maker removed. Can someone come out to my home and remove it please. It takes up room I would rather use for ice trays. There is also a wire on the back side of the ice maker inside the freezer that if you should touch it, you get a shock. It is exposed. Please contact me @ 630-204-8407 or e-mail. bettyjankowski@comcast.net. It was purchased at Home Depot in Oak Brook, IL. and is still under warranty.
Thank you,
Betty Marcheschi
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
The ice maker is plugged on the back wall of the freezer. There are only 3 phillip screws holding it in place. Not a hard task if you have a handy person in the area.
Unplug the unit, remove the screws, and then unplug the unit and remove it.
Sgt 48
Posted on Jun 01, 2008
LG french door refrigerator ice maker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 11, 2010 | LG LFC25770ST (250 cu ft) Bottom Freezer...
ICE MAKER NOT WORKING LBC22518WW (LG REFRIGERATION)
Hello, just like your problem, our ice maker just stopped making ice. We solved the problem by unplugging the refrigerator for about 2 hours leaving the freezer door open.
It started making ice a few minutes after plugging it back in. Obviously the line that supplies the water had frozen and this allowed it to un-freeze.
We didn't remove any of the frozen items in the freezer, at the two hour mark, everything in the freezer was still mostly frozen.
Thanks
Jul 13, 2010 | LG LBC22518 Bottom Freezer Refrigerator
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
Ice cube maker not working. digital display not
The ice fan is frozen. It is located behind the rear panel inside the freezer2.gif drawer. I had the same problem with an LG refrigerator in November 2008 that was fixed under warranty. (There is a Kenmore model that is made by LG.) They replaced the fan and housing, and the panel duct assembly (both because a design revision provided a way to drain the water that was freezing the fan), and the main controller board (presumably because there was a new defrost program, but also because of the Energy Star settlement.) If your refrigerator is out of warranty, you can remove the freezer drawer to get at the panel behind it. Remove and defrost the fan housing. Drill some small holes in the bottom of the fan housing for drainage. Put it back together and see if that solves the problem.
Oct 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridgew/ice maker. ice tastes like sulfer.
This sound like you need a water filter change to the refrigerator.
Aug 05, 2009 | LG LFC20760ST Stainless Steel Bottom...
I am interested in the lg bottom freezer french door refrigerator but my current refrigerator does not have an ice maker and is not near a water source, since the ice makers are standard on these...
You will want to make sure it stays in the off position or it will constantly cycle thinking it is making ice and burn out the water valve coil. If you are definitely not going to hook it up removing the ice maker will accomplish the same thing and give you a few more inches of storage.
Eric
Jun 08, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
LG LFX 25950SB, the Ice Maker is not working, just hear a click
heatman101
klh
Feb 22, 2009 | LG LFX25960 Bottom Freezer French Door...
Ice maker not making cubes
You may have ice built up in icemaker where the water goes into it.  You will have to remove the icemaker and to get the ice cleared out.  Once that's done, you should be ok.
Jan 13, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Lg refrigerator LFX25960SW
do not purchase lg refrigerators or products. they are junk!
Aug 15, 2007 | LG LRFD25850 French Door Refrigerator
LG LRBN20510WW Bottom Freezer Refrigerator Logo
143 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
