Question about Atari 2600 Console
I have an Atari 2600 console. The Player #1 slot is stuck in the firing position. It is not the joystick. I swapped out joysticks and no change. It is something with the console. What can I do to fix this?
  • Atari Master
  • 427 Answers
Well the controller ports inside of the console might be needed to be resoldered or the controller ports might be broken or it could be just bad controllers then.
Posted on Apr 20, 2012
ROBOTKING
  • 14 Answers
SOURCE: Atari 2600 controller problem
I HAVE BEEN REBUILDING ATARI SYSTEMS FOR 20 YEARS AND THOUGHT I HAD SEEN EVERYTHING, AND I WOULD THINK IT TO BE A JOYSTICK PROBLEM. THEY CAN BE REBUILT WITH NEW CONTACTS, BUT I AM THINKING THE PROBLEM MUST BE INTERNAL. I CAN ONLY SUGGEST TRYING ANOTHER DECK. THERE MUST BE SOME PROBLEM WITH THE PINS IN THE PLUG PORT.
IT
Posted on Oct 19, 2007
  • 6 Answers
SOURCE: Atari 2600 jr. console + paddle controls = Don´t work !!!
If your controllers work on a friends, then it indicates your VCS is faulty. It's very rare though for a VCS to fail in that way, but the controller chip for the game controllers can go faulty at any time. It's more common to see a faulty one on the actual ATARI XE range of computers than on the consoles.
Have you tried both ports on the VCS maybe ? Only some games will use both though.
You mention it being 'paddles', but not joysticks or just controllers. Are you actually testing it with a game that uses the paddles type controller? like the breakout type game?
The controllers of all types for a VCS are the same, but if using a different type of controller, note that there are at least 3 different types available - but all look the same (all use a 9-pin plug).
The basic ones where introduced by ATARI in the 1970's, but later Commodore and Amstrad used their own different types of configuration which caused some confusion.
Some older joysticks had a slider switch underneath allowing you to select Amstrad, Commodore, or ATARI configuration. It's safe to try/use the wrong type for testing, so try different ones if possible.
Hope that helps a bit.
Posted on Dec 17, 2008
SOURCE: paddles don't work for atari 2600
Sounds like a pin has come loose from the main board inside your unit. If you are handy with a soldering iron, and not opposed to opening up your console then, you can take a look at the connection between the connector and the board... If you are not comfortable with this idea, then you can find a competent electronics repair shop on the internet. You could also replace that unit with a "new" one from a number of internet shops or eBay, then retire that one. Hope this helps.
Posted on Dec 22, 2008
SpotBert
  • 231 Answers
SOURCE: Atari 2600 Console Power Adapter
This place sells replacement adapter (not original) for the Atari 2600.
http://atariace.com/atari/accessories.php
Posted on Dec 24, 2008
  • 18 Answers
The Atari 2600 adapter has the following information on it:
Input: 120V AC 60Hz 12W
Output: 9V DC 500mA
Positive tip
Make sure you test the power supply before you use it. I have 2 original atari power supplies, and they are both putting out about 15V DC, which may be why my atari's aren't working anymore!
Anubis
Posted on Jun 17, 2009
What was the main difference between atari's 2600 and the 5200?
the 5200 had a 360 degree rotating joystick on the controller, and was introduced as a higher end complimentary console for the 2600
Jan 29, 2013 | Video Game Consoles & Games
Joystick problem
HI,
You will have to get this repaired from local Atari Authorized Dealer
I will let you know the contact details
Oct 12, 2008 | Atari 2600 Console
I was just given an Atari 2600 for Christmas and the controllers do not work. The red trigger button works but the joystick does not, on either side. Is this something that can be corrected or is the...
it has dirty contacts so you unscrew the bottom then put some contact cleaner in it then move the joystick around alot for a good 5 minuets so the cleaner will clean it then the joystick will work
Jan 01, 2011 | Atari 2600 Console
Atari 2600 problem with left control plug on console
Well maybe the controller ports need to be resoldered then try soldering then with a solder iron.
Nov 21, 2009 | Atari 2600 Console
The joysticks for my atari 2600 will go in every direction but up. is there a way to fix this?
Wow. I miss my old Atari. Those old Atari joysticks were not too complicated. What it sounds like is the little metal disc for your up has worn out. You just need to take it apart and replace that disk. Its basically just a flexible square so when you press down it completes the circuit. You can probably get one from another joystick (even some of the newer ones).
Nov 01, 2009 | Atari 2600 Console
ON my atari 2600 my paddlel controlers don't work in the left port. but my regular joystick dose. what do i do?
Unless you are an electronics expert with a soldering iron, I would just get a replacement paddle from eBay or online seller. I occasionally experienced this problem in the early- to mid-1980s - getting new paddles always did the trick. If you are up for a challenge, look at the joystick pin and then look at the paddle pin - you will see at least a one-pin difference between the two. Check the paddle pin to see if one is physically damaged, then compare the pin on the console itself. Have fun!
-Tha Mp3 Doctor
Dec 21, 2008 | Atari 2600 Console
Possible Control Port Issue for 2600
Superdrafan:
you sound like you have a conection problem within you atari
open the Atari up and look to see if there are any dry solder joints from the joystick ports
just dabbing the point with a solder iron shold freshen up the connection
The Gameboy: you sound like you have dirt in your joystick
open it up and clean the connections with a cloth and spirts
Sep 04, 2008 | Atari 2600 Console
Joystick problem
you might find something on ebay, BE CAREFULL READ THERE FEEDBACKS
Jul 02, 2008 | Atari 2600 Console
Which Joystick?
YES!
The joystick controllers are backwards compatible with the original 2600 system so you also technically get 2 new 2600 joysticks with this set.
Dec 11, 2007 | Video Game Consoles & Games
IT
Oct 19, 2007 | Atari 2600 Console
Atari 2600 Console Logo
55 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
MegaByteMe
MegaByteMe
James Wishart
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
