Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Could you tell me what the oil mixture is for the saw
Http://www.mccullochpower.com/node7887.aspx
Mcculloch web site says 40:1 ratio
There are 128 ounces in a gallon
divide 128 by 40 = 3.2
So you need 3.2 ounces of 2-cycle oil per gallon of gasoline
Don't forget, you also need bar-oil in reservoir that lubricates chain
Mcculloch has manuals for you to download
I suggest you get a copy of your manual while available, and read the manual
Most companies don't have old manuals, so a few years from now, your manual may not be found
Posted on Oct 10, 2010
Does this take straight gas?
Your saw most likely requires a gas/oil mixture. a 1:50 mixture (1 part oil to 50 parts gasoline) is common among newer saws. Some older saws (20 years or more) require a richer mixture, commonly 1:40. I recommend you consult the users manual for the saw.
Hope this helps.
Apr 26, 2011 | Garden
Saw starts but wont build up any power it fouled two plugs back to back do i have gas mixture wrong
sounds like a rich mixture stihl and huskvarna oil has the same makeup dealers have test tubes for warranty service that tells them what oil was used and will not warranty if wrong oil is used with the proper oil your saw will last for a long time cheap oil does not have the additives needed too keep rings free and inhibit carbon buidlup
Jan 19, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
What is the right fuel oil mixture???
ok im not a mind reader ,,,so what chain saw is it???? il have a go at this one,,,,,
most chain saws take a 50 to 1 mix if there not very old,,,but thats not all of them,,,ok?
some run on 40 to 1 mix,,,,old chain saws run on 25 or 30 to 1 mix? and very old saws run on 10 to 1 mix,,,,now you see you did not help me not telling me which saw you have,,, did you?
if its a new saw to be safe run it on 40 to 1 oil mix its a two strok so if there is a little smoke then its getrting oil to the bearings so it wont seze up?
Dec 02, 2010 | Garden
Can u tell me the best fuel/oil mixture for Stihl TS360 Many thanks
Use Stihl 2-cycle oil and it is 50:1 (see page 19)
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
Talk to the mechanics at Stihl that must clean out the carbon caused by rich mixtures, they will tell you the same.
Your OM follows;
http://www.stihlusa.com/stihl_ownersmanuals/TS360_Manual.pdf
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 22, 2010 | Saws
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the gas/oil mixture for poulan wild thing chain saw? Thank You Roger
I have a manual for that saw that says the mix is 40:1- 3.2 oz. of oil to 1 gal of gas .
Dec 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I picked up this McCulloh chainsaw at a yardsale a few days ago. I am not sure if it takes regular gas or 2 cycle gas...and the oil-- could you tell me the mixture? It is a gas powered 32" chainsaw. Other...
It will take 2 cycle mix. I run all of my saws at about a 40: 1 mixture. I could likely run them at 50: 1 even but 40 is a little safer. The older saws had to have a richer mix due to the oils not being as good back then, not to mention the changes in engine technology. You can buy the 2 cycle mix at just about any hardware store. It will have a chart that tells you how much oil to mix in with the gas for a given ratio. If you really want to be safe with an older saw you might try it at 32: 1 Hope that helps you.
Jul 19, 2009 | McCulloch Garden
Gas to oil ratio for chainsaw
You will want to mix at a ratio of 40:1. that is 40 parts gas to 1 part 2-cycle oil.
Mar 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
360 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
