Question about Razor E300 Scooter
Trying to tighten the chain tensioner on a razor scooter
I had this same problem and it took me a while to figure it out and there is nothing in the manual that helps. It comes down to this, both parts of the chain, top and bottom, go above the tensioner.
Posted on Sep 23, 2012
Go to a web site
Posted on Apr 22, 2012
5 Suggested Answers
  • 38 Answers
SOURCE: Razor Electirc Scooter, the chain keeps falling
If the chain is too long than shorten it by using a chain breaker. Or you don't have a chain breaker take the scooter to a bike or more preferable a electric scooter shop and have them do it. The problem could also be your chain tensioner check to see if it's tightening the chain.
Posted on Aug 18, 2010
  • 38 Answers
SOURCE: How can I put chain back on my E200 razor electric
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
  • 850 Answers
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Posted on Jul 18, 2009
ptblz7022
  • 3 Answers
SOURCE: Razor e200 scooter the chain tensioner spring - where does it attach?
tensioner should fit on axle or behind the axle on the edge of thew fork where hardware should be mounted to adjust tensioner
Posted on Jun 10, 2012
My e300 razor run but will not move
Check to see if the chain is moving when you apply throttle. If the chain is not moving but you can hear the motor working then it is likely the chain has come off the motor sprocket. If this is the case then follow the steps in the user manual to refit the chain and adjust the tension.
Aug 12, 2014 | Razor E300 Scooter
Tip
How To Lubricate E100 E200 E300 Razor Electric Scooter Chain Easy Way
<utube src="JKzj7Bu2Ink"></utube>This video will show you an easy way how to lubricate the chain on your Razor Electric Scooter. This process is shown on the E200, it should also be the same on the E300,and E100.
on Aug 03, 2013 | Razor E300 Scooter
How do you replace the chain tensioner on a Razor E300
Theres an 8mm nut holding it onto the pin that goes thru the frame.
Take that nut off and remove the tensioner. Put some grease on the new pin where the tensioner goes. Put the end of the new spring into the hole in the frame next to the pin hole. Hold the tensioner in place and put the pin thru and the nut back on. You should be able to get the chain back on the sprocket without loosening the axle nuts. Hope this helps.
Aug 03, 2014 | Razor E300 Scooter
Chain keeps poppin off
These are the instructions for adjusting the chain. They are taken directly from the manual available at http://ep.yimg.com/ty/cdn/razorama/e100e200e300manual.pdf
To adjust the chain:
1. Loosen the axle
2. Loosen the brake anchor (this is attached with the small bolt in the long slot on the left side of the rear fork)
3. Tighten the tension adjusters on the axle 1/8 to 1/4 turn to tension the chain. Tighten both adjusters the exact same amount to maintain the wheel alignment.
Note: this system of adjusters is common to motorcycles and BMX
bicycles so I your are not familiar with it, if you know anyone who is,
they would not have a problem adjusting it for you.
Chain tension: The chain should be "just not-quite snug" in other
words, not taut or sloppy loose. BE CAREFUL NOT TO ADJUST TOO TIGHT. The tensioning system can easily impart too much tension and snap the chain or bend the motor output shaft. Turn the adjusters 1/8 to 1/4 turn at a time and recheck the tension each time.
4. Once the tension is good, tighten the axle and brake anchor bolt. Test run the scooter. Readjust as needed.
Jan 02, 2014 | Razor E100 Electric Scooter
Jun 10, 2012 | Razor E200/300 Electric Scooter Battery
Scooter has new batteries and still barely runs up slight hills its the E 200 scooter
On the Razor E200 check the chain is fully tightened & lubricated & you will be amazed what incorrect tyre pressures will do (36psi) to the power of the scooter.
Jun 17, 2011 | Razor E100 Electric Scooter
The chain keeps coming off of my daughters MX500. Is there a way to tighten the chain or the chain tensioner. Is there something else that could be causing it to come off?
The chain usually comes off because it is not tight enough or the chain is not aligned correctly with the sprockets. Check the chain tensioner to see if it is keeping the chain tight and not moving even though it is tight, if it loosens, replace the tensioner. Check the chain for any broken or worn spots or links, if any are found replace the chain.
Jun 15, 2010 | Razor MX500 Dirt Rocket
How can I put chain back on my E200 razor electric scooter?Everything is in the way.
Your done!
Apr 24, 2010 | Razor E200/300 Electric Scooter Battery
Razor Electirc Scooter, the chain keeps falling off, I cannot see how to tighten it....help
Dec 17, 2009 | Razor E100 Electric Scooter
Razor E300 Scooter Logo
3,294 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
