Question about HTC Hero Smartphone
Have HTC hero, it will no longer connect to data/internet, I tried disconnecting and reconnecting thru the options, but it still will not pull up web page on browser or weather for that matter on front page screen.
    Guru:
  • 352 Answers
It sounds like you have turned off the Mobile network option (that is the data option for Sprint, other carriers might be different).
Try this, add a widget to your screen that will turn on the data connection:
-long press on the home screen > Widget > Settings > Mobile network
This will place a widget that will allow you to turn on and off the mobile network. Make sure it is on and then try your connections again.
Good luck.
Posted on Oct 26, 2010
How to so a hard reset on a htc hero
Please note that all data will be deleted from the HTC Hero as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
  1. Turn the power off. If your HTC Hero is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and release the Power button
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the HTC Hero. Once the wipe is complete, the phone will reboot to its factory fresh state.
Oct 26, 2011 | HTC Cell Phones
How do you get the upgrade the htc hero to 2.1
Getting Started
Before you run the ROM Update Utility (RUU), make sure you have done the following:
  • Backed up the data on your device.
  • Standby or hibernation mode of your PC has been disabled.
  • Close all running applications on the PC.
  • Set aside approximately 25 minutes to allow the device to update.
  • Charged the battery to at least 30%.
  1. Download HTC Sync for Android.
    Install the HTC Sync software on your PC if it is not already installed. This software was included in your HTC Hero gift box. The minimum required HTC Sync version is 2.0.28. We have HTC Sync for Android 2.0.40 available for download; newer versions might be available from www.htc.com.
    HTC Sync for Android 2.0.40 (39MB)
  2. Download the Hero 2.1 MR Upgrade executable file.
    Hero 2.1 Upgrade (113MB)
  3. Connect your HTC Hero to your PC.
    Use the supplied USB cable.
    If the HTC Sync application appears on the screen of your PC, you may simply dismiss the wizard by pressing the Cancel button.
  4. Run the Hero 2.1 MR Upgrade RUU file.
    Follow the on-screen prompts to install the update for your HTC Hero
WARNING: During the upgrade process, do not attempt to make/receive calls, press any buttons on your device or disconnect the device from the USB cable as this will stop the update and your device may be rendered inoperable!
If you have a problem with the connection between your device and PC be sure to check the connection type in your device. This can be done in the device via Settings -> Connect to PC. Ensure that HTC Sync is selected.
Mar 09, 2011 | HTC Hero Smartphone
Cant connect to the internet using sprint 3g
Usually a restart should clear this up. Be aware that 'Ev' means 3G on the HTC hero.
Are you using a custom rom? What did you do recently?
Feb 28, 2011 | HTC Hero Smartphone
How should I use my htc smart phone as modem in my laptop?
  • This tips work for Android 2.1 based HTC phones
    • HTC Legend
    • HTC Desire
    • HTC Wildfire
    • HTC Aria
    • HTC Hero
  • Software needed: HTC Sync 3.0
  • Download Here. (Installation guidelines provided)or http://www.htc.com/www/SupportDownload.aspx?p_id=312&cat=3&dl_id=982
  • Computer's OS (32 and 64 bits versions):
    • Windows XP
    • Windows Vista
    • Windows 7
  • Others:
    • Of course you'll need to subscribe to an internet package with your mobile operator for this tip to work.
    • USB cable to connect your phone to the PC (usually provided with the phone)
Intro
The aim of this tip is to make use of your HTC phones as a modem http://en.kioskea.net/contents/pc/modem.php3
, connecting your PC,netbook or laptop to the internet.Thus allowing you to browse webpages, send/receive emails, use your instant messaging software, anywhere and at anytime.
Here's how:
Download and install HTC Sync 3.0
Turn on the "Data Connection" feature of your phone (usually configured by the mobile operator)
To enable it:
  • From the Home screen, select MENU>Settings > Wireless & networks> Mobile networks > Check the box next to "Data Connection"
  • Connect your phone to the computer using the USB cable, the synchronisation process is an easy one.
  • In the Connect to PC interface, select "Internet sharing" option and tap on the Done button.
Source Official HTC website http://www.htc.com/in/
Hope this helps.
Jan 10, 2011 | HTC Cell Phones
How do I use my HTC hero 200 as a modem for my laptop
Connect your phone to your laptop USB with th data cable. You will get a window with three options. Among the three options, select the option called "Mobile network sharing".
If its still not working,  install HTC sync software from below link
http://www.htc.com/www/supportdownloadlist.aspx?p_id=283&act=sd&cat=all
and try again.
Hope this helps
Thanks
Oct 29, 2010 | Computers & Internet
Network Connection error
This is a tutorial on how to add APN settings to HTC phones for your network providers. Example phone used is a HTC Hero but process is same for all HTC models.
Android APN and Data Settings Change for HTC Phones
  1. Go to settings -> wireless controls
  2. Go to Mobile Networks -> Access Point Names
  3. Click Menu and select New APN
  4. All you need to add for most networks is just the APN setting which can be obtained from your simcards network provider
  5. Press Menu and Save
  6. You are ready and have configured data connection settings.
Enjoy your HTC phones unlocked for Voice and Data for any network. see video below
May 14, 2010 | HTC Reusable Screen Protector Hero /...
I want Modem Driver for HTC Hero phone using sprint network
Using the HTC Hero as a USB Modem
In order to use this functionality, the HTC Sync software must be installed onto the PC first (http://blog.brightpointuk.co.uk/synchronise-htc-hero-microsoft-outlook).
The HTC Sync installer is included on the SD card that comes in the Hero sales package, or alternatively is available for download from our FTP site:
ftp://ftpaccess:Brightpoint1@ftp.brightpointuk.co.uk/Technical%20Support...
You can download the software to your PC, or insert the microSD card into a suitable reader to access the software.
Once installed, on the Hero device browse to Settings --> Wireless Controls and enable the option to enable Mobile Network Sharing. Now connect the Hero to the PC via the supplied USB cable. Windows will detect the new hardware automatically and install an "HTC Remote NDIS Network Adapter": Provided that your Hero has a cellular data connection, you will now be able to use that connection from your PC.
(If you found this information helpful please rate this answer with a big thumbs up and thank you for visiting Fixya!)
Jan 27, 2010 | HTC Cell Phones
HTC Hero disconnects from network!
maybe orange dont have a large area of coverage on your city/town. try using a wi-fi connection with your home wirelless network, and if you have same problem, try reset factory default.
Jan 16, 2010 | HTC Hero Smartphone
Htc touch diamond no longer connects to the internet
All you need to do is to check your packet data conmnection.
Sep 29, 2009 | HTC Touch Diamond Smartphone
HTC Hero Smartphone Logo
226 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
