Question about RCA L42WD250 42 in. LCD HDTV
My RCA Scenium mdl L42WD250 will not power on. Power LED comes on green for about 5 secs, then blinks red 5 times in succession repeatedly.
  • 67 Answers
SOURCE: 42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Posted on Jul 25, 2009
snakehead
  • 1074 Answers
SOURCE: rca scenium
you are having a problem in your power supply, standby power supply where the microchip is situated take the set to a tech to have it repair.good luck.
Posted on Mar 30, 2007
dsacco86
  • 1077 Answers
SOURCE: RCA L42WD250 42 in. will not turn on
Try unplugging it for 30 mins. If it still has the problem, it may have when into protection mode.
When this happens, a part in the TV when bad. The protection mode keeps the TV from staying on to prevent further damage.
At this point, I would use the warranty on the TV. Being that it's only 6 months old.
Posted on Feb 09, 2009
SOURCE: Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
sherrie
michigan
I followed the solution e-mailed to me. My 50 in. phillips magnovox plasma had no sound or picture. I removed the back panel of the tv ( 55 screws) and removed the circuit board in the center of the tv. There are about 5 or 6 wire connections that you have to unplug, but they are all different in size so it's ot a problem when reconnecting. Take the circuit board to a tv repair shop. There are 2 capacitators side by side at the bottom center that were bulgeing. 3300ua 10 volt. I had them replaced by the repair shop while I waited. They had (1 ) 25 volt and (1) 16 volt available. The voltages do not have to match each other. The higher voltage is better. I put the tv back together and HURRAY!!! it works. I have been searching for a solution since last summer, Thanks to fixya.com my problem has been solved. It only cost me $35.00 total.
I thought the tv was going to the curb, thank god I didn't toss it. I hope this solutions works for the endless number of people who have posted this same prolem. GOOD LUCK!!!
Posted on Feb 12, 2009
  • 33 Answers
SOURCE: My rca L26WD26D does not power on - using the
The most common failures with LCD/ DVD combos is a failure in the DVD transport mechanism. The DVD transport mechanism is an easily replaced subassembly, that can be purchased for less than $200 in most cases. The best bet is t replace this mechanism ensuring that you purchase it from a vendor who will purchase it back if it dos not fix the problem for some reason.
In the event that the DVD player replacement does not solve the problem, the second most common problem is LCD's is the power supply module. Assuming that you do not want to have a shop repair this unit, search for a power supply module online and replace it yourself, ensuring you can return it if it doesn't resolve the problem.
There are other things that cause that symptom on LCD tvs that are beyond the scope of this discussion.
Posted on Apr 29, 2009
I have a Sony Bravia KDL-60W850B tv that went out in a thunderstorm. Red led blinks 3 times then repeats.
This doesn't sound like a firmware issue, test the various power supply voltages for starters
Mar 19, 2018 | Sony Televison & Video
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Rca scenium
Mar 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA L42WD250 42 in. LCD HDTV Logo
174 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
