Question about HP DeskJet 5550 InkJet Printer
The printer does not turn on even if I press switch to turn it on.
  • 50 Answers
Check your power source for plugged into wall. your power block can have a broken wire usaully at the transformer end. If you can check the voltage output u could know for sure. its not easy to access the pins without shorting them out. some printer run at up to 24v so be carefull or have a qualified person do it.
Posted on Oct 10, 2010
The orange lamp is blinking even though it has been pressed and power turn off. Not working
Unplug your printer and see if this clears that issue once you plug it back in. Even though you turned off the on/off switch, unplugging it will clear its memory.
I hope this works for you,
Regards,
Nico
Jul 06, 2011 | Canon Office Equipment & Supplies
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
The cover open signal comes on when the printer is turned on even tho the cover is securely closed. Can I bypass this cover open warning as the printer works when this light is not on.
Find where the switch that detects if the cover is open or closed is. Once you find it see if it is stuck in a position that tells the printer it's open. If for some reason it is broken, try placing an object that will press down the switch and tell the printer it's closed.
Mar 01, 2011 | Epson Stylus 1520 InkJet Color Printer
Dell all in one 942 ink jet printer reads "clear paper jam" there is no paper stuck. How do I fix?
Try this; Remove the cartridges, disconnect the usb cable, turn off the machine, unplug the power chord and switch off the adaptor from the wall switch, leave the machine for few minutes while you do some cleaning, like cartridges contact points, clean the rear panel door, also open the front panel door and check for any foreign particles, you should remember that even a small/tiny piece of thread or hair can create this problem. Now connect the power chord, switch on the wall switch, and power on the printer without the cartridges installed and the usb cable connected. Use the Power Button the switch on the printer. Leave it Switched On for few minutes and again turn it off, install the cartridges, connect the usb cable and again reboot the unit. Press the power button once and again keep pressing when it starts booting. If the problem still persists, your printer needs service.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | Dell 942 All-In-One InkJet Printer
How to config the IBM 1532 's print margin
Turn the printer off
Hold down Go and Return, then turn the printer on. Release both buttons when the display changes to Performing Self Test
After a couple of seconds the display will change to Registration
Change the size of the margin:
a. Press Right Arrow until the asterisk to the right of the number you want to change starts blinking and then press Select
b. Press the Left Arrow or Right Arrow to change the value and then press Select
Once you have made all the changes that you need to, press Return one time
Press the Left Arrow until Exit Diagnostics is displayed and then press Select
Dec 30, 2008 | IBM Infoprint 1532 Laser Printer
Ran system suite 8 and now printer isn't working
my printer lexmark x4550 when switched on it says Clear Carrier Jam, then press tick so i dont know what's that means, thanks
Nov 22, 2008 | Lexmark X5470 All-In-One InkJet Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Epson 760 Problem
I found this procedure to work for the Epson Stylus 760 printer. The error is indicated by all four lights on the printer flashing and appears to be caused by the internal counters of the machine being exceeded. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
1) Turn off your printer, ensuring that the print head is at its home location and locked in place as normal.
2) Remove the four screws securing the top cover two at the rear and two at the front under the lift up cover and lift the cover off.
3) Remove both ink cartridges.
4) When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1.
5) Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down.
6) When the paper-out LED flashes, release the buttons.
7) Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button).
8) The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
9) Insert the cartridges as normal and replace the cover.
Mar 13, 2008 | Epson Stylus Color 760 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
