Question about Epson Office Equipment & Supplies
I have an Epson Stylus Photo PX650. The display
I have an Epson Stylus Photo PX650. The display says I have a paper jam... but I haven't!!! And it won't let me print until the problem is cleared!!! The display says "Load paper and press start. If the error does not clear, repeat the procedure." I've done this over and over again, the paper feeds through but the error message remains on the screen! How do I clear it?
jackboy
  • 2985 Answers
SOURCE: Epson Paper Jam Error
Discover the rest procedure for your particular printer
Usually involved switching off- then holding down a couple of button whilst you switch on
for example Service and stop.
Try www.fixyourownprinter.com for more info
or
www. stevesdigicams.com/forums
Posted on Jun 10, 2008
SOURCE: Epson Stylus Photo R200 and R320 Status monitor in Vista
Hi - I have the R320, I downloaded the following driver epson11889_easyprint_310a from epson site. I uninstalled previous driver which was for the r200, installed this one and everything OK Status Monitor works fine.
Brand
Posted on Sep 17, 2008
SOURCE: Epson Stylus Photo R800 (Manual Feed) missing option
I found this answer on Apple.com support discussions.  Worked for me.  There is more information available on the discussion, but this was enough to fix my problem. Try Page Setup. Select to format for your printer. The choices for different all media should now be available under the Paper Size. This is a change from previous practice of creating a separate printer for each type of media.
Matt
Posted on Jan 14, 2009
SOURCE: All lights flashing on the Epson Stylus photo 870
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
Posted on Apr 29, 2009
sherlyn c
  • 134 Answers
SOURCE: I need a repair service for EPSON stylus photo
Please log on to epson.com. Click on north america, then usa. Go to the drivers and support page. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
Posted on May 04, 2009
I have an Epson stylus photo PX 660,which is displays an error message that,paper jam inside and in real sense there is no any paper jam inside.show me how i can solve this problem.
Check the rollers (the inlet and outlet for the paper) and blow them out with a blower,vacuum, or a can of air. That should "fixya" right up. Lmk if it doesn't and I'll get down to specifics with more info from you as well
Feb 12, 2015 | Epson Stylus Photo Px660
Epson px650
Run the maintenance switch that should cure the horizontals but the dark printing ????? I just don't know ........ sorry
Aug 17, 2014 | Epson Stylus Photo PX650 Multifunction...
Px650 not printing full page, cutting print area on right
you can maintenance ................. cleaning or deep claening ......click
it is in page set up ................. main........ preferences...
Nov 18, 2013 | Epson Stylus Photo PX650 Multifunction...
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jam has been cleared, but paper jam message remains.
Try these steps and see if it resolves your problem. Hope it helps:
Follow these steps to clear a paper jam:
  1. Press the cp_button_45_er.gif Start button to eject the jammed paper. If that doesn't work, go to step 2.
  2. Turn off the Epson Stylus.
  3. Lift open the scanner and remove any paper inside, including any torn pieces.
  4. Close the scanner, then turn the Epson Stylus back on.
Aug 02, 2009 | Epson RX595 Photo All-In-One Printer
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
279 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
