Question about Kenmore Dryers
How to install the belt in the dryer kenmore 400 series.
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 10, 2010
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
I cleaned and made sure there were no loose connections. the dryer will not start. could it be the push to start relay or an issue with a fuse. is there a common item that is usually fails on the kenmore...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 10, 2011 | Kenmore 400 6942 Dryer
Kenmore 400 need the map for install the dryer belt
One of these diagrams should help you with replacing that Kenmore belt...
Kenmore Dryer Belt Diagrams and Replacement
heatman101
Jan 05, 2011 | Kenmore Dryers
Kenmore 400 series dryer heats but does not turn, how do I access drum belt
to open dryer:
http://www.partselect.com/dryer+open-cabinet+repair.htm
belt:
http://www.applianceaid.com/images/belt-config.JPG
Dec 11, 2010 | Kenmore 400 6942 Dryer
Kenmore series 400 electric dryer when I press the start button won't start bar
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 31, 2010 | Kenmore 400 6942 Dryer
Kenmore 400 series dryer will not heat?
LP dryer flame goes on for a few seconds and them goes off
Oct 27, 2009 | Kenmore 73952 Gas Dryer
I have a kenmore 400 series dryer model no heat
Srart by pulling each thermostat wires and tape them together until you find the bad one. You should have 3 of them to test.
Oct 25, 2009 | Kenmore Dryers
Kenmore Belt Tensioner
At the link you will find the belt configuration for your machine and others.
Dryer belt configuration
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Kenmore 400 series electrical dryer
I have a 400 series kenmore dryer that just quit running after 10 min. into cycle. breaker in house checked and is ok but no power to dryer. what could the problem be
Oct 18, 2008 | Kenmore 73952 Gas Dryer
is the belt broken? some dryers have a belt broken switch.
Oct 18, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
