Question about Whirlpool Inglis IP8200 Dryer
The dryer stopped just all of a sudden, What could be the problem? It is plugged in, has cooled off for several hours and still will not start. Any suggestions?
    President:
  • Whirlpool Master
  • 2,651 Answers
Ill assume that this is an lectric dryer, if thats the case the most common issue is a faulty thermal fuse assy, locted in back wall of unit. after disconnecting power supply, you can find the thermal fuse behind back cover its a white thermostat usually with 2 blue wires (-----------------------) probably about this long, a simple continuity tesat with a power meter will tell you good or bad.
Posted on Oct 09, 2010
Testimonial: "It worked, but then burned out again, what could the problem be there? My husband put it together wrong? or is there something else wrong?"
Lancia delat hpe was running fine,suddenly it stopped.tried to start it for hours using a booster.nothing...no sparks from plug or coil.the car was left to cool down for 2 hours.and then it started...
hi thats a common problem i would replace the crankshaft sensor first there bad for working when cold then breakdown when hot hence the reason no spark when warm
Nov 23, 2013 | 1995 Lancia Delta HPE
Led lights on control panel are flashing and dryer will not start, check filter light is on
leave this machine unplugged for several hours. Make sure all the lint is free and clear. This machine needs to be plugged for several several hours to reset itself unless your model has a reset option available.
Jun 05, 2012 | LG DLG2524 Gas Dryer
My dryer is a whirlpool electric dryer that was brand new in 1998. The dryer was on, working fine...suddenly it just stopped. It was making a clicking noise. It refused to cut back on when I pushed the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Whirlpool GEW9250 Electric Dryer
Old 2nd frig stopped working, no cooling, no compressor running, only light in compartment. Any breakers or things to check?
Of course check breakers, then unplug unit from wall for several hours (let unit compressor cool) then plug back in. If after plugging it in you continue to hear a "clicking" sound on rear of unit either start device on compressor is bad or compressor its self is gone.
Oct 16, 2009 | Refrigerators
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
1999 Saturn SL1 trouble starting when warm
It was the coolant temperature sensor. It was telling the car that the coolant was always cold, therefore when starting a warm engine it was being flooded. $$$
Jan 05, 2009 | 1999 Saturn SL
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Dryer won't start
If you are getting s slight HUM when you press the start button,your motor is experiencing some problems. If you do not hear a hum, and after letting the dryer cool down for several hours, it suddenly works again, your motor has an internal short and is shutting itself down via the internal overload. If there is no hum of any kind, even after letting it cool off for a long time, then either there has been a failure of a part in the line such as the door interlock switch, the timer contact or there is a thermal overload in the back of the dryer, down by the blower, it is white in color and it has probably opened up.
Dec 14, 2008 | Roper Dryers
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Whirlpool Inglis IP8200 Dryer Logo
579 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
