Question about Trendnet Wireless Home Router TEW651BR
Does it need a modem or works on it's own ?? - Trendnet Wireless Home Router TEW651BR
    Scholar:
  • 42 Answers
It doesn't need a separate modem; it replaces a modem in your home network. If it's properly connected to the phone line, and you have an internet service provider (ISP) supplying you with a broadband connection, and the PC is connected to the router, then it should all work fine.
If it isn't all working fine, the most likely problem is either that the wires aren't connected in the right places, or that the PC's internet connection isn't set up properly (e.g. if you changed from dial-up with a modem to broadband with a router).
If you have recently changed from dialup to Broadband, and you're running Windows, use the Network Connections wizard to set up the internet connection. In Windows XP you can do it this way:
1) click on Start
2) move the mouse to Settings
3) click on Control Panel
4) double click on Network Connections
5) click on File
6) click on New Connection Wizard
7) follow the instructions.
Your ISP should have sent you a CD-ROM to help you to connect, so insert the CD when prompted by the New Connection Wizard.
Sometimes you can just insert the CD into the computer and you'll be prompted to do everything necessary to connect to the internet. BT, for example, do it this way.
Posted on Oct 09, 2010
I uninstalled the modem because it did not work. I need to reinstall modem to see if it works and if it doesn't what to do next?
if the modem is ethernet modem
there is no need to install
just install the ethernet driver
it will work fine
Aug 27, 2010 | Dell Computers & Internet
Modem not working
You need to hard reset your modem. By doing that, unplug the modem from the power outlet. Look at the back of the modem, you will see there a small red button. You need to press that button. You need to get a pin or pen to press that reset button. Press the reset button for 5 mins. Monitor the power light. It will change to orange light and it will restart. Once it restarted, you can release the reset button and wait for the lights to come up. Since you did the hard reset. You need to configure the modem with your username and password from your ISP.
You need to access the gui or firmware of your modem. If it ask for username and password. This is the time you need to contact your ISP. They will help you to configure the modem. Once they provided you the username and password ofr your modem. Write it down so you will have a copy and in case it happen again you know what to do. Username and password for the modem is different from the username and password for your internet. You also need to enter the username and password for the internet so you can use the internet. If you get a red light for the internet, that means the username and password is incorrect.
If this didnt work. You need to replace your modem.
Jul 02, 2010 | D-Link (DCM-202) Modem
Modem won't work thru splitter
actually modem will only send and recive signal through direct cable feed it will not work by spillter, but dont worry there is device avalible in the market which will help you to connect the modem directly and also act as a spillter too better go the shop from where you brought this modem and describe your needs they will help you.
Jun 08, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
DSL Modem not working.
meaning of the red light on your modem is that iy=t is not working properly(modem) so all you need to do is power cycle it by unplugging the power cable to the power outlet and to make sure just press the reset button for 5seconds... usually it is at the back of the router/modem...
hope it works and pls do vote on my profile after that thanks
Apr 08, 2010 | AT&T High Speed DSL Modem
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
Will my DSL 300G Modem work
it will work if the subscription would also be an adsl line. but you need to know the new providers settings including type of connection (pppoe, dhcp, etc) and the vci settings. once you place the settings correctly, it will work.
Nov 05, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
Di-524 router problem
You do not need a password for cable. You need to make sure that your router is using DHCP. Whenever you connect something to your cable modem, you MUST turn off everything. Then turn on in this order:
1 Turn on cable modem and wait until the modem syncs with your ISP.
2. Turn on your modem and wait until the router and the modem sync up.
3. Turn on your PC
Your cable modem will remember the MAC address of the last device that was plugged into it, which is why you must turn off your modem to clear out the modems memory.
Jun 04, 2009 | D-Link AirPlus DI-524 Wireless Router
Is the modem needs driver update
Usually the no dial tone error is not a driver problem but rather a problem with the modem itself. Modems are really finicky and even the slightest surge through the phone cord from an electrical storm can cause the modem not to get a dial tone. You will need to replace your modem and that will solve the issue.
May 29, 2009 | Genius GM56PCI-L (FM9648001) Modem
Modem not working
turnoff the moderm and unplug the modem from the outlet, wait 10 sec. plug it back in.
it should work. (modem do need reset, once a while.)
Oct 19, 2008 | Computers & Internet
Speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
Oct 19, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Trendnet Wireless Home Router  TEW651BR Logo
100 people viewed this question
Top Trendnet Computers & Internet Experts
youbrokeit
Level 1 Expert
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
