Question about Frigidaire Gallery Series GLRT86TEW 30" 18.3 Cu. Ft. Top Mount Refrigerator w/ 4 Half-Width Glass Sh...
18 ft frigidaire 5 years old used seasonally fan and compressor run but no cold
    President:
  • Frigidaire Master
  • 2,651 Answers
Thata a close call, if you indeed know that the compressor is running.. should be hot when on..and still no cool in freezer section. sounds like a MAJOR refrigeration issue, requiring sealed system repair.. its close because the manufacturer covers selaed system repairs for 5 yrs. ck your manual and with the manufacture first, because you can replace the unit for cheaper than doing repair out of warrantee,
Posted on Oct 09, 2010
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
Hi, I have a Frigidaire Commercial upright freezer that runs but does not get cold anymore. Its only about 5 years old. Could it just be a freeon problem?
Frigidaire are notorious for having compressor issues (very expensive) however if the unit is under 5 years old it IS still under warranty!
Thanks and please rate me!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie GOFAR Services, LLC
Aug 26, 2011 | Frigidaire Refrigerators
My refrigerator isn't staying cold nor is the
Look and see if coils need cleaning below. Do a good clean. Feel the compressor, if it's hot to the touch or cold it may have a bad relay. A relay can fail to drop circuits (causing the compressor to overheat) and open (causing the compressor to be idle).themobilian_2327.jpg
May 09, 2011 | Frigidaire Side by Side Refrigerator 23...
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
I have an 18 cu. ft. Frigidaire that the compressor is running on but the unit isn't getting cold enough. Is there a way to charge the refrigerant?
Odds are great that if you clean the condenser coil (the coil under your frig) and check the Condenser fan to be sure it is running. (little fan under the frig) Bet you its one or the other..*****
Sep 23, 2008 | Frigidaire Refrigerators
Frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire refrigerator
check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
Apr 27, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire side by side
booster on compressor not condesor, if you needed a "boost" to run compressor sounds like you got bad compressor.
Feb 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Series GLRT86TEW 30" 18.3 Cu. Ft. Top Mount Refrigerator w/ 4 Half-Width Glass Sh... Logo
117 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
