Question about Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00
Hello we have Bradford hot water tank model #MI65R6DS13. Our problem, I keep having to press the tanks reset switch for us to get hot water. At the same time after I press the reset switch we have hot water but it quickly becomes scalding hot to a dangerous point. We will have this hot water again for a day or so, when it all of a sudden becomes cold and triggers the reset switch again. Do you have any answers, The tank is 6years old am I looking at a replacement already? Thanks Hugh Cloutier
  • 349 Answers
No the top thermostat is the first place I would start to replace. They run about 14.00 more than likely it isn't controling right. Turn power supply to water heater off and replace thermostat.
If you was getting scalding hot and then turning cold without tripping the thermostat it would be the top element working and the bottom one bad.
Bottom element good it will give you luke warm water for a while then gradually turn cold because it's heating the bottom of the tank.
Hope this will help you out.
Posted on Oct 10, 2010
Reduced Hot Water
Water heater 14 years old, probably has never been flushed, Flush recommended at least every 6 months, Build up inside tank may be to late to flush, but you can try or replace heater.
press the helpful button
Feb 11, 2016 | Element Water Heaters
I turned up the water temp on my gas water tank, and water leaked from the side pipe..do I need to repalce the pressure release valve or is this normal?
Any time your pressure release valve goes off you should replace it. the t&p valve responds to the temperature and pressure its possible that the setting you chose was to hot, or its possible that the relief valve was just worn out. I would replace that and keep your temp setting between B and C. another possibility is thermal expansion, check and make sure your expansion tank is good and if you don't have one I highly recommend it.
Jun 28, 2014 | Bradford White M45036fbn 50 Gallon Natural...
I have a Bradford White water heater (model# MITW50L6LN10) that started making noise yesterday. Tonight when the family got home we started a bath for the kids and surprise surprise no hot water left in...
Probably cheaper to fix existing water heater.
The problem might be the power vent, or the power vent might be short cycling because the gas control valve is bad, or vacuum switch has gone bad.
Call Bradford White and get their recommendation for your specific model.
http://www.bradfordwhite.com/contact.asp
http://www.bradfordwhite.com/supportserv.asp
http://www.bradfordwhite.com/findaserial.asp
Bradford White is very good brand of water heater
Rheem, Richmond, GE are good.
I prefer the AO Smith, American, State, Reliance, Craftmaster. Kenmore, Whirlpool brand since air intake screen is located on bottom of unit and can be inspected and cleaned without removing burner.
Feb 09, 2013 | Water Heaters
We have a bradford defender model # MI403S6FBN7. How do we reset it. lost manual
Water heaters are a huge field of knowledge. Problem is not 100% clear.
There is a resettable thermal switch on the combustion door. This switch is round and has two wires that come from gas control valve. Thermal switch trips when combustion parts have not been cleaned and they cause overheated condition, or sensor reads temperatures above 180, or thermal switch has gone bad, or gas control has gone bad.
http://waterheatertimer.org/images/Whirlpool-Resettable-ECO-8.jpg
Add a comment with more information for continued help.
1) Bradford White support:
2) Bradford white mi403s6fbn is 6-year-warranty 40 gallon tank-type gas water heater with Icon electronic gas valve, and atmospheric venting.
Older models have the dial-type Robert Shaw or White Rodgers gas valve.
Open following link to see age of Bradford White:
3) Bradford white has 'product manuals' and 'service manuals' on following link:
Product manuals have general information and advisories that people can read about water heaters.
Service manuals are for plumbers and technicians, and do-it-yourselfers for testing and repairing water heaters.
http://www.bradfordwhite.com/documentation/residential/gas.asp
4) Typical manual for your product shows different gas valves, lighting instructions, and advisories, and troubleshoot checklist:
http://www.bradfordwhite.com/images/shared/pdfs/manuals/238-44219-00J.pdf
5) Add a comment with following information if you want specific help with servicing water heater.
What are you trying to reset on the water heater?
What are the symptoms, and what have you noticed, and what have you tried so far?
Which gas valve does your water heater have? Please open typical manual and view images of the three basic gas valves.
When was water heater last serviced and cleaned?
How old is water heater?
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | RTO Bradford White M-1-20U6SS 19 Gallon...
My fan on top of my bradford white water heater model mitw40L6en13 went out. What kind of of exhaust/blower should i get to replace it? Thank you
Contact Bradford White and ask which blower is correct:
Get model number and serial number from label located on side of tank.
This information will help BW find exact information for your product.
Jul 28, 2011 | Fasco Bradford White Hot Water Heater...
How do you remove a tmp valve out of a propane gas water heater and are they universal or do I have to go to a Bradford White dealer? Thanks
yes you can get a universal one at any hardware store[about 15$]. shut off cold valve at top of tank and drain tank through drain at bottom of tank.you only need to drain enough to get the water level below the t&p valve. you should use dope and teflon on the new threads of the valve to ensure no leaks. a big cresent wrench or pipe wrench will work to unscrew the valve in a counterclockwise direction
Oct 23, 2010 | Fasco Bradford White Hot Water Heater...
I own a Bradford White Corp. Electric Hot Water Heater. It has two thermostats, one upper and one lower. Model # M-1-40S6DS 13, ser# XK0300351. My problem is the red button on the upper control trips...
Hello. If you turn off the power and drain the tank then examine each of the heating elements you will find that the upper element is deteriorated. The fix is to replace the heating element. Actually though my practice is when one is bad the other isn't far behind so for a few dollars I change both when I have the tank drained. Joe
Feb 28, 2010 | Water Heaters
Reset button triping on bradford white electric water heater
replace upper thermostat, and hi temp limit, usually made in one piece, also make sure the new stat is pushed up tight to the tank when you install it.
Dec 05, 2009 | RTO Bradford White M-1-20U6SS 19 Gallon...
Water Heater drain leaks and has caused rusting on tank
If you're sure it's the DRAIN, just get a garden hose cap for it (your other option is to replace the valve - drain tank, replace valve, refill).
NEVER CAP THE RELIEF VALVE DRAIN!
Sep 18, 2009 | Fasco Bradford White Hot Water Heater...
Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00 Logo
747 people viewed this question
Top Fasco Water Heaters Experts
Gil Shultz
Gene Haynes
Are you a Fasco Water Heater Expert? Answer questions, earn points and help others
