Question about Frigidaire Refrigerators
Frigidaire larder fridge RL60003B My mother's 3 year old fridge is not defrosting. The inside back is covered with a thick layer of frost. I have turned it off, cleaned the drainage hole and wiped away the frost. Once turned back on the problem has reoccured.
SOURCE: frigidaire ice maker
TRY MAKING THE TEMP COLDER
Posted on Sep 27, 2008
  • 3 Answers
SOURCE: ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
Posted on Oct 02, 2008
jumptrout51
  • 3361 Answers
SOURCE: freezer not defrosting
Your defrost drain line is frozen over.Remove everything from the fridge and turn it off for 24 hours with the doors standing open.
The drain line will thaw and you will return to normal operation.
You could also turn the fridge off, remove the freezer floor panel and back panel. Take a hair dryer and thaw out the drain hole. Takes about 2 hours.
You decide which procedure to use.
Posted on Apr 23, 2009
SOURCE: Where is the defrost timer located on GE
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Posted on Jun 05, 2009
  • 2501 Answers
SOURCE: LG GC299BA Fridge working but noisy, freezer broken.
It sound rather like one I used to have (but worse) which was never 100% satisfactory. When it eventually failed we called in a repair man who said it had been faulty since it left the factory.
I advise you to scrap it and but a new one. If you have any similar problems with new equipment, go back to the supplier within the warranty (if you have an extended warranty, then call them out now!).
Posted on Jan 23, 2010
Why frost layer so thick about 1 inches? Is this 3 mth old fridge normal or need servicing?
That is not normal. Make sure the doors are sealing properly. Otherwise, I would say you have a defective unit.
Jul 29, 2016 | Frost Refrigerators
Hi, I have a Hotpoint RLA51 larder style 'frost free' fridge. Its approx 6 years old. For the past 3 years its been frosting up meaning every 8 weeks we have to defrost it manually. I bought a new...
high chris
check to see if you have a drain at back/near bottom of the fridge,if so, clean out with neat clorine bleach.if you have a fridge thermometer adjust fridge to run at +5c(optimum temp) and cover all food with cling film to cut down on condensation.
regards
geoff.
Aug 26, 2010 | Refrigerators
Freezer temp very unstable... lots of ice build up on inside inte
This appears to be a defrost problem. Either the defrost heater is burned out or the defrost thermostat is defective. Look into the rear wall of freezer for a layer of frost building up that will tell you that there more than likely is a large area of snow and frost building up on the evaporator coil. Once you manually defrost the coils you will be able to see the part number WR51X10038 Defrost Heater. It has a glass tube on the outside so it will be easy to spot if the defrost heater element inside is burned out. If you change the defrost heater I recommend that you replace the defrost thermostat part number WR50X10054 Defrost Thermostat. The defrost controls on your model come from the mother board so the is no defrost timer or adaptive defrost. The mother board make the decision when to defrost. When you are able to unplug and inspect the evaporator coils in back of freezer back wall panel let me know what you find, Thanks Sea Breeze
Sep 18, 2009 | GE PTS22LCS Top Freezer Refrigerator
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Model 550, the iside is getting a layer of ice
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Aug 22, 2009 | Refrigerators
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
LG frost free fridge freezer GR-359sq
defrost drain is blocked - probably with ice. take the back panel off inside the freezer and melt the ice off with a hairdryer then follow up with hot water till it flows away freely. this takes some patience. if fault reoccurs then get back to me
Aug 27, 2008 | Freezers
Fridge losing coldness
Defrost problem. Either defrost heater, defrost thermostat, or defrost timer is bad.
Sep 05, 2017 | Frigidaire GLRT184RA Top Freezer...
Refrigerators Logo
111 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
