Question about Zebra 105Se Thermal Printer
Zebra 105se blank labels problem
I had to replace the roller that the printhead prints against. Now, each time a label is printed, a blank label is fed out. I Called Zebra and they calibrated it, but offered no solution to my blank label problem.
tks,
Josh
    Problem Solver:
  • 15 Answers
I would say the roller isn't the problem. I had the same problem on many Zebra printers, but often the calibration helped. Then it could do, when printing task label is for larger/longer than the label size is set in the printer system (conflict of software with printer settings after calibration). It could be set too down to bottom in Y axis. Or it could be in the software settings - as action after print - not sure.
Try to open the printer queue while the label is printed and check if the label has proper number of pages or there's 1 page more. If it is the right number - then the problem is on printer side (recalibrate, reflash it). If the number is about 1 higher, the problem is with settings of the label size (barcode software, printer settings) or action after print on PC side.
Posted on May 30, 2008
My zebra 105Se keeps printing blank labels.
Do the labels come out right when you print locally? That is the first thing to see. Serial devices over a network are tricky. Baud rate and what to do with CR LF, stop bits, parity etc. need to be right.
Jun 04, 2014 | Zebra 105Se Thermal Printer
Advancing blank labels inbetween printing
Do you use adhesive labels? It looks like the printer is unable to make the difference betwen the labels. Verify that the printer it's not set on Continuous mode for the media type. Verify if there is any label (or pice of label) stiked on the upper media sensor (gap sensor). You can locate the upper media sensor using the User Manual (page 74). There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
You can clean the sensor with an coton cloth dampened into isopropylic alcohol.
Here is the link to user manual:
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
Dec 03, 2013 | Zebra 105Se Thermal Printer
Not printing all labels
Do a calibration, this should fix the issue. Also make sure that the label stopper (silver peg on label holder) is pressed firmly against the labels. This will stop the labels from sliding around during a print, throwing off the calibration. Also check to make sure the sensors are free of any dust.
Jun 17, 2010 | Zebra 105Se Thermal Printer
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
Can I print in color with a Zebra 105se
Thermal printers don't have any 'color' of their own; the 'printed' text/numbers are actually only areas subjected to heat from the printhead which exposes the color of tiny beads of ink that are on the paper itself by melting them. Use a fingernail to 'score' the paper and you will see it change color just as happens in the printer.
Oct 14, 2009 | Zebra 105Se Thermal Printer
Our Zebra 105se printer has started missing labels. For ex., it will be printing a batch of 40 and every third or fourth label it shoots out an empty. sometimes it puts out two empty labels but in the end...
Clean your platen roller. It's the white rubber roller (that turns and pulls your labels through your printer) located under your printhead. When this gets slick it causes your labels to slip while printing.
You should use rubbing alcohol to clean it. Your computer guys may also have some cleaning wipes in a foil packet that you can use.
Jul 13, 2009 | Zebra 105Se Thermal Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Right side of label faded or blank after replacing printhead
Things to check:
1. Move the pressure arm further towards the outside of the printhead. Adjust if needed using only the minimum pressure required in order to achieve uniform print quality.
2. Inspect the printhead to ensure it has properly engaged the alignment pins. I have had after-market printheads that did not line up correctly and required "surgery" to make them properly seat on the mounting pins.
3. Check for worn platen roller bearings. If they're are sufficiently worn, one side of the platen roller will be slightly lower than the other.
4. Consider replacing the platen roller. They do wear out and require replacement. Zebra part number 40038M IIRC.
5. Check the printhead parallelism adjustment. The procedure is in the maintenance manual.
Steve
Jul 15, 2008 | Zebra 105Se Thermal Printer
Printing solid black across the label.
Sounds like a defective printhead.
Reinstall the old one to see if the problem remains or not.
Steve
Jun 25, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se missing line
Try cleaning the thermal printhead. Zebra makes thermal printhead cleaners or you can use a qtip and some isopropyl alcohol.
Make sure the printer is turned off before doing this.
May 19, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
586 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
