Question about Bosch HBN 7052 GB Stainless Steel Electric Double Oven
Bosch oven heater ring replacement
How do i remove the fan in the bottom oven in order to replace the heater ring, as the fan blocks the top screw on the heater ring.
  • 1 more comment
  • Anonymous Jun 19, 2008
    Got exactly the same problem, there is a fixing screw behind the fan that I cannot get to so I cannot get the old element out. Tried pulling at the fan blade (after removing the fixing screw!) but it won't come of.
  • martin_coxy Aug 17, 2008
    Me too.. What a poor design.. I can see half of the screw, the fan only needs to be 2mm less diameter, or have a notch cut in it and I could get to it..
  • teejay-1 Nov 20, 2008
    Hi I have the same problem, British gas fixed mine and I asked him and it is a special tool to remove the screw. I have had 3 elements in 1 year.
    Very bad design fault
Hi, the fan is held in place with a left handed nut, once undone, then remove the steel drive washer by giving it a light tap, finally it is a case of shear brute force applied evenly. All you need is a 10ml spanner and a medium size cross head screwdriver plus a bit of muscle.
Posted on Feb 18, 2009
Hi. I nearly gave up with this but after reading jazabel's solution i decided to give it one last go. I sprayed a small amount of WD40 onto the centre spindle and then pulled on the fan blades with two pairs of pliers. I must have taken about 5 or 6 really big efforts but it did finally come off.
Posted on Sep 19, 2009
I tried using brute force, but no go.
As a last resort, I gripped the fan spindle with pliers and gently twisted the fan this did the trick !
They must get stuck on with use of the oven.
Posted on Aug 24, 2010
4 Suggested Answers
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
barkencoa
  • 3463 Answers
SOURCE: just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Jan 03, 2009
SOURCE: Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Posted on Dec 09, 2009
My walloven it does not heat at all only the fan and the light work
Their is a good chance your fan oven element has blown and needs replacing.
isolate the cooker, remove the cover inside at the rear of the oven cavity held on by 4 screws normally, you may have to remove the oven lamp glass as well (depends where its sited) then you can see the round element. Just use your eyes with a torch and check to see any furred or broken bits on the floor of the cavity or for any anomalies. See image below,as you can see where it has blown at the bottom of the picture. If this is the case, you can order a new element online with the make and model number of your cooker. You must have a little amount of engineering knowledge to perform this. Good luck! 25250147-hxs5rfaijc4c2ocig4ruktbd-5-0.jpg
Oct 20, 2014 | Bosch 27" Double Wall Oven HBN56
HOW TO REMOVE FAN FORCED ELEMENT
All I needed was a phillips screw driver, a small hex socket drive and an 8mm wrench.
1. Turn off the mains at the switch board. There might be a switch near the oven or stove too, turn that off as well. Check that the power is off!
2. Remove the screws holding the oven to the cupboards. Mine was held in by 4 timber screws on the edge.
3. Slide the oven out of the wall. I used a small table to support it.
4. Remove the hex drive screws that hold the top lid on.
5. Using a trusted multimeter CHECK THAT POWER IS OFF! There are now exposed power terminals.
6. Undo the supply power terminals and remove the cable. I taped mine up.
7. Remove the back cover - more hex screws.
8. Pull the spade terminals off the heater element.
8. Inside the oven remove the shelves and side racks. They pop off the wall.
9. Pull the rear fan shield towards you. It should pop out at the top and then lift off 2 small tabs.
10. Remove the phillips screw at the bottom of the heater element.
11. Remove the 2 spring clips.
12. The element can now slide down and towards you.
13. Replace the element and put it all back together in reverse order.
Oct 08, 2014 | Ovens
How do i replace bottom element in blanco oven model bso632
Hi Ron.
Unfortunately I do not have the schematics for this specific model. The fan assisted oven has a top grill element and an element in the fan housing. The fan housing is located inside the oven cavity at the back and protected by a cover held by 4 screws. Here a video showing how to replace the fan assisted element. If there is also a lower element at the bottom of the cavity, this can be reached removing the panel at the bottom of the oven. Here a video showing replacement of the bottom element.
Dec 19, 2011 | Ovens
Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
Jun 11, 2011 | Bosch Ovens
How do i replace the heating element in a diplomat aca3200 oven?
make sure the oven is switched off.remove all trays etc from oven,remove 2 posidrive screws from bottom of fan plate,remove fan plate,the element is around the fan,remove 2 posi screws from where the element goes through the side of oven and the one screw that holds the top of the element to the back of the oven.slowly pull the element out and remove the 2 poz and neg spade connectors.refit as removed.
Dec 30, 2010 | Ovens
NEED TO FIT REPLACEMENT ELEMENT IN LOWER OVEN TOP SCREW BLOCKED BY FAN
To remove the fan unscrew the fixing nut clockwise as though you were tightening it, as it is a left hand thread, hold the fan blades at the same time to prevent the fan turning.
Ensure power is OFF.
Hope this helps.
Dec 11, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
Main fan oven does not work, conventional main oven does work
The element is where you said and yes it can be replaced without removing the oven. Remove the bacplate from inside the oven and you will see the element and fan. Remove the screws from the element and gently pull it forward then remove the 2 wires and keep hold whilst you fit the new element. Replace screws in the element refit the backplate job done.
Jul 29, 2009 | AEG U7101-4 Electric Double Oven
Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Apr 18, 2008 | Neff U1721 Double circotherm Electric Oven
Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
Aug 15, 2007 | Neff U1721 Double circotherm Electric Oven
Dec 10, 2006 | Bosch HBL 455 Stainless Steel Electric...
Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
671 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
