Question about Frigidaire ATF6000ES Front Load Washer
Basket has fallen loose in front of washer. basket sags loose in front. belt in back is on okay and basket turns freely.
  • 1,531 Answers
Take off the top of the waher and look at the suspensions springs and make sure they are attached.you may also need to remove the back panel and look at the shocks to see if they are in good working order.
Posted on Oct 09, 2010
Testimonial: "gives me a place to start so thanks for the comment"
I get F51 error on my Kenmore Elite Oasis washer. During the spin cycles, it makes a loud, grinding noise. It appears that some of the plastic over the tub has been sheared. What do you recommend? ...
First, what is your model number?!
The F-51 error code on this washer indicates that the machine control board in the console detects a motor RPS (Rotor Position Sensor -- tachometer) failure. This can be caused by a number of different problems. You could have a bad RPS sensor, a failed motor, a wire harness connection problem or an item stuck between the spin basket and the outer tub that is interfering with spin basket rotation. A water filling problem could also cause this code to be displayed since the basket would have excessive friction if water is not entering the machine properly. With the washer off, spin the basket to see if it rotates freely. If you detect resistance or suspect that an item is stuck between the basket and the outer tub, you will likely need to remove the basket and check this area. Remove the basket and check for foreign objects or debris.
If the basket spins freely, make sure that your water supply cut-off valves are fully open. Shut off the water supply and remove the hoses from the connections on the back of the washer. Place the ends of the hoses in a bucket and briefly turn on the water supply to check the flow and water pressure coming from the end of the hoses. Check the inlet water valve screens for deposits or debris that could interfere with the water fill. The motor will begin to spin the basket before the washer completes the filling function. If the filling is slow, it could cause the F-51 code.
If the water supply is okay, you could have a wire harness connection problem, failed RPS sensor or a number of other failures. Unplug the washer to disconnect electrical power before accessing internal components. Internal metal edges in the washer can be sharp. Protective gloves are recommended.
I recommend that you unplug the washer and access the control board first. Check the wire harness connections on the P10 and P5 plugs first. Measure the resistance through the motor and the RPS sensor as shown below. This may point you in the direction of your failure. If you need more help, submit additional details.
Oct 10, 2013 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Neff integrated washer/dryer. The machine seems to turn on and take in water but doesn't start to spin. It sit's for half an hour making clicking noises then will start spinning and finish the...
Assuming that it pumps out okay then could be the motor.....Check belt is okay not fallen off , next motor brushes, they wear out after around 6 yrs ,
Apr 01, 2011 | Neff W4380X1 Front Load Washer
Showing f50
The F50 error code flashes when the motor rotor sensor (RPS) senses no motor rotation. Does the basket turn freely? If not, the cause of the friction will need to be determined. If the basket turns freely it could have a loose wire connection or a failed component.
Jan 22, 2011 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Miele Novotronic W828 Water Control System Front Load Washer
Hello Ellen, welcome to fixya. I would begin by removing the rear panel and checking the belt and insure the basket pulley isn't loose as well. If the belt is in tack ( not broke ) but has come off that sometimes is caused by a loose or bent pulley, hence the suggestion to check the pulley. If the belt is broke, it may simply be a matter of normal "wear & tear" and just time to replace it. Hope that helps point you in the right direction. Please take a moment and rate this info according to it's helpfulness or let me know if I can assist you further. Thanks for visiting "fixya" today and good luck. Macmarkus :)
Jun 03, 2010 | Miele 300 Front Load Washer
Front load shows wash but basket not moving
I FOUND A BELT POPPED OFF OF A MODEL LIKE YOURS ONE TIME. TAKE THE BACK PANNEL OFF AND SEE IF YOUR BELT FELL OFF. UNPLUG YOUR MACHINE FIRST! AND IF YOUR BELT IS OFF CHECK YOUR PULLY IT MAY BE LOOSE IF SO REPLACE IT AND YOUR BELT.
Jan 12, 2010 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Drum wont turn
sounds to me like the belt may have fallen off the back of the drum.
look under the lid and see. if a wd, should be simple enoughto put it back on by removing the back cover to refit.
turn the power off though.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
My Maytag washer leaks badly around the bottom on the spin cycle
Sounds like you might need a new pump belt. They are inexpensive and easy to replace. Unplug the washer and with the water out tilt it back so that you can see the bottom. You have a main drive belt that goes from the motor to the big pulley in the middle. There should be a second belt that goes from the motor to a smaller pulley which is the pump. Make sure that this pulley turns freely in both directions. One direction is agitate and the other is discharge. If it does and your belt is loose a new belt might do the trick.
If the pulley does not move freely take off the front panel, two philip screws about 3 inches up from the bottom of the front panel. Inspect the pump. One time I found a scouring pad in the pump!! If after inspection the pump still does not move freely you may need to purchase a new pump. Find the part number and check out prices on-line. The pump is relatively easy to replace. Good Luck
Jan 26, 2009 | Washing Machines
Worn out front rim of plastic tub surrounding stainless basket
well not sure about yours but some front load washers have a five year warranty on the tub but you have to pay the labor which is between 100-150dollars
Dec 29, 2008 | Kenmore Elite 45986 Front Load Washer
Helpp
If you have removed the drive belt from the rear pulley and the inner spin basket does not spin freely, you either have a drum bearing seized up on you, or something binding between the spin basket (stainless steel tub) and the outer tub shell. First, you need to reach inside the wash tub with the washer empty. Place the palm of your hand at the 12 o'clock position and push straight up. There shouldn't be any play in the spin basket. If you can feel the basket wobble up and down, you have either a bearing problem, or a spin basket support (spider arm) broken on the back of the spin basket. If there is no play at all, you probably have something caught. Small articles of clothing can sometimes get pulled between the tubs and usually ends up around the support shaft in the rear. This will obstruct the basket from spinning freely and could eventually cause damage to the drive motor, spin basket and/or tub bearings. You can use the instructions for replacing a rear tub bearing that I have posted under my Tip and Tricks for instructions on how to disassemble and inspect the tub. The bearing may not be bad, but you still need to check to see if anything is binding the spin basket against the tub shell and inspect the spin basket supports. Unfortunately, you have to disassemble the washer to be able to inspect any of these items I mention. I hope this helps you.
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 94802 washer belt overheats, smokes, and melts
sounds like perhaps the trannsmission has locked up and is not spinning freely, therfore the belt is meeting resistance and not turniing.( try turning the trans. pullley( where the bsck of belt is wound)does it turn freely??? try turning the tub from inside does it spin at all??? before i condemn the tranny i would check for article of clothing fallling between the tubs, holding from spinning, also ive seen (nails/screws/bra underwires,etc..) poke through onr of the holes with in the tub abd stuck to the outer tub also preventing the tub from spinning, look closely to all the inner basket holes!!!
Apr 08, 2008 | Kenmore 94802 Front Load Stacked Washer /...
Frigidaire ATF6000ES Front Load Washer Logo
220 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
