Question about GE (PSS26MSRSS) Side by Side Refrigerator
Every two to three hours a rattle low behind motor area of the fridge
    President:
  • GE Master
  • 2,651 Answers
Is your water line hooked up for the ice maker, its possible that the unit is calling for water to produce ice, usually cycles 2-3 hours
Posted on Oct 09, 2010
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
We have a e381t model refridgerator/freezer. there is a rattle/scraping noises coming from the fan in the freezer part. There is ice behind the protective sheet that separate the fan from the main area. Is...
If there is noise of the fan rubbing with the frost build up on the freezer then it is confirmed that the defrost timer is faulty. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 17, 2011 | Fisher and Paykel Refrigerators
Rattles on high speed and soft click click sound on low how do you get to the fan
Assuming you're talking about the HVAC blower motor, it is located behind the glovebox. There is a plastic access panel under the passenger side dash area, take this off and also open glovebox and release tab in left corner. This will allow you to see the motor. See picture below.
Sep 01, 2011 | 2004 GMC Envoy
Freezer and fridge compartments dont work. Have checked fuse sounds like the motor is'nt working. Please can you advise on problem and whether it is worthwhile repairing - The fridge is 16 years old Thank...
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution.
Feb 22, 2011 | Refrigerators
I have a Magic Chef compact fridge. There was a lot of ice build up in the freezer compartment. I attempted to defrost it last night, but I also tried to break away the ice before it was completely...
either the defrost heater element or defrost thermostat is open behind the rear wall where all the ice buildup was and is bad or the defrost timer in the front area isn't working to defrost the unit on a 12 hour schedule,you will need to test each component
Oct 14, 2010 | Refrigerators
Hello - came back from holiday and my maytag gz2626gekb had defrosted and all food was lost, we thought that one of us had left the door open by mistake so switched it off at the mains then back on and...
If the entire freezer section had warmed up i would be looking at either the condenser fan motor (located behind fridge in compressor area) or the relay and overload assembly (attached to the compressor) as your most likely suspects.
Usually if the relay and overload fail the compressor simply will not run or you will hear an audible buzz and click sound from the component.
The condenser fan motor should be running whenever the refrigerator is on. If the fan is stalling it will cause the compressor to overheat and shut off.
Now if some of the freezer items were still frozen, you may have a defrost issue causing a restriction in air flow within your unit. Your most likely culprit for this would be the defrost control board located in the refrigerator compartment top right corner above your control housing. Part number 61005988.
Jun 13, 2010 | Maytag ZigZagW / B Side by Side...
I cleaned out my fridge completely today. Took all the shelves out, cleaned the interior, all the glass over a three hour period. The freezer is working just fine, the fresh food area is nice and dry but...
Manufacturers suggest that it takes approximately 24 hours for the temperature to stabilize in both your freezer and fresh food compartments after being turned off for an extended period of time. Adjust temperature settings to the "half-way" mark for both freezer and fresh food compartments. Allow a period overnight and recheck the temperatures. Also check the condenser coil (usually located underneath the appliance). If clogged with dirt/lint, it needs to be cleaned (carefully) with a condenser coil brush (can be purchased at Home Depot or Lowe's). Prior to cleaning condenser coil, turn off appliance (there is a condenser fan motor and blade operating while on). Be careful not to damage copper tubing (refrigerant in tubing)!
Feb 16, 2010 | Refrigerators
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Fridge not cooling, motor constantly running
Sounds like low on Freon find the evaporator up in freezer hiding behind back wall or under freezer floor. when removed look at the frost pattern if it is only partial covered in frost , good chance it needs a shot of gas Freon like stuff gas. not sure in your areas what requirements costly in The Great White North. But if there is only a great block of ice from four my best seen it started right where the door panel ends and freezer began 36 hours to defrost. So if ice cube is what greets you Defrost Problems check Defrost timer stuck, Defrost thermostat, Defrost Element, check all wiring in freezer were the last 2 are located.
Mar 17, 2017 | KitchenAid Refrigerators
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
