Question about HP LaserJet 3055 All-In-One Printer
The USB port on the printer is loose and therefore not communicating with my computer.
    Scholar:
  • 42 Answers
You can open up the printer and try to fix it, but in fact you will probably need a new part which will have to be soldered in.
An easier solution would be to use the parallel port connection, if there is one. Newer printers don't always have them, and I don't think the 3055 has one.
On the other hand, newer printers often have an ethernet connection, and you should be able to use this instead of the USB. I'm pretty sure the HP 3055 has an ethnet port. You'll need an RJ45 wire. You can get a USB to RJ45 adapter if you need to plug the other end of the cable into your PC's USB port (e.g. if your PC has only one ethernet port and you're already using it for broadband).
Hope that helps a bit. Good luck!
Posted on Oct 10, 2010
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Why does my epson R280 Givers me a Communication Error, what does this mean
It normally means that the signal between the printer and computer had been corrupted or interrupted. Check that your USB cable is not damaged, unplugged or even slightly loose. Unplug and re-aligns in both ends. Use a different USB port on your computer if you can.
Keep the USB lead and printer away from unshielded mains or hi-voltage cables as as they can corrupt data signals. Next reinstall the printer driver. If all this fails, try your printer and lead on a friends computer. If it works, look for the problem in your laptop otherwise maybe it's time to buy an Epson wireless multifunction printer.
Aug 16, 2014 | Epson Stylus Photo R280 Series
Where is the printer port on my acer aspire 7551-2961?I did not get an user guide and am a lost senior citizen trying to communicate with my grandchild.MCV
Most printers now use the USB port instead of the older parallel ports that has several input/out pins. Some printers (new-out-of-the-box) do not come with the USB cable, therefore purchase one for your printer if it requires a USB cable. The computer should have more than one USB ports to plug into.
Nov 01, 2010 | Computers & Internet
Printer unable to communicate with computer.
Are you using the wireless network printer function or is the printer connected by a USB cable? If you are using the wireless network, launch the printer's Wireless Setup Utility and run through it. (Check for problems with IP, signal strength etc.)
For USB, try resetting the printer (unplug it from the wall for 10 seconds). Check that the computer is looking for the printer on the correct port. Click Start > Settings > Control Panel. Double click on the Printers folder and right click on your Lexmark printer. Choose Properties then click on the Ports tab. Check that one of the USB port options is checked. (If you have a newer OS, Start > Devices and Printers and then right click on the printer.) Also try a new USB cable and a different USB port. If you have a print server or USB hub, try a direct connection.
I hope this helps.
Apr 22, 2010 | Lexmark X3350 All-In-One InkJet Printer
My printer and computer are not communicating at
If the software is installed for the printer, there is only two things you can do.
Plug a USB device that's already working into that port. If it's working, It'll install the driver.
If it's not working, try another port. Change your USB cable to another one. Also, in the BIOS, set the USB port to high speed.
Aug 09, 2009 | Zebra LP 2844 Thermal Printer
Port not recognized - printer and computer do not communicate
unplug printer ,shut down printer, shut down computer, then restart computer, and plug printer back in after computer is fully up and running turn printer back on
and that should solve the problem
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Lexmark X3650 Printer
PC not reading printer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jan 29, 2009 | Lexmark X2350 All-In-One InkJet Printer
Communication problem printer lexmark2600
Jan 12, 2009 | Lexmark X4530 InkJet Printer
Unable to print
To fix a fouled install :
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
HP LaserJet 3055 All-In-One Printer Logo
210 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
